Is a double pumper "better" then a VS carb ?
Old May 3, 2002 | 01:49 AM
Blackened's Avatar
I feel my car should be quicker then it is now with the 750VS Holley I have. I used to have an Edelbrock 750 that just felt a lot quicker. Do you guys think a doulbe pumper would give me any gains at all ? Thanx
Old May 3, 2002 | 09:46 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
In theory, when either a 750 DP or VS carb is wide open, they should flow the same and therefore make the same power.
In reality, every side-by-side comparison I've seen the DP makes more power.
Go figure.
The conventional wisdom is to a use DP for manual tranny, VS for auto.
The other part of the conventional wisdom says use a DP if your setup can handle the WOT mash at the line without bogging. If not, then use a VS. To back that up, I know 4 fast guys who run out at Bandimere, all 4 have auto trannies, all 4 use DP Holleys. Of course, they have loose torque converters to go with their race-only setups.
Old May 3, 2002 | 04:49 PM
Blackened's Avatar
I just dont feel the power like I did with my Edelbrock anymore. Maybe I do NEED a DP. Hmmm....
Old May 4, 2002 | 07:40 PM
PerthZ28's Avatar
Hey Blackened...
...what's a Blue LED dash mod? Got any pics?
Old May 7, 2002 | 01:11 PM
9.0L Firebird's Avatar
Spend some time with the carb before tossing it. Whick secondary spring are you using? The white/yellow spring will open faster but may drown the motor with a tight converter. What do your plugs look like? if they are black it is a pretty easy call. A DP will make more power on the dyno, but may not be faster on a street car. FYI, I run a 1250 Dominator on the street, but it took some time to get it tuned right. Dan
www.nescaracing.com
Old May 7, 2002 | 02:32 PM
Blackened's Avatar
A good friend let me borrow his 850 DP. It has annular boosters, jet extensions in the back and it's currently jetted with #74's up front and #78s in the back. It runs better at WOT but getting it to idle correctly, starting on the first key or stop dieseling is another story...
Old May 7, 2002 | 03:09 PM
Jester's Avatar
Go figure.
In reality, a VS carbs secondaries never open all the way. Thats why DP's always make more power. Thats why it's usually a good idea to be a little more generous with sizing if you wanna run a VS.
I run a Dominator and a double pumper on my two cars, both on the street, so you can guess which one I like. However, I agree that you shouldn't ditch your VS just yet. It should still show a healthy gain over the Edelcrock, you just need to spend some effort in tuning it.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
buckshot63
Sep 10, 2015 09:15 AM
383cam
Sep 9, 2015 06:01 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
