what cfm
what cfm
what cfm is the stock q jet on an 83 transam and what does cfm mean
CHRIS
1983 firebird transam
edelbrock performer rpm intake 360*k&n intake 160 theroostat gitting trans raced up and lots and lots of plans 4 the future
CHRIS
CFM means Cubic Feet per Minute..it's the standard unit used to quantify flow of air.
Opinions on the stock Q jet CFM vary because it depends greatly on how far the secondaries open, which vary from carb to carb depending on model, setup, and tuning.
Personally I say it's not any more then 650cfm.
It's actually 800 CFM but only if the secondary air door opens a full 90*. Most of them stop at about 75* in that era. Usually it's as simple as filing down the stop on the side to get full opening although some carbs will bind up the tension spring beyond 80* (the last 5-10* you will feel a considerable increase in tension).
A 4bbl carb's CFM rating is measured at defined temp and barometric pressures and with a 1.5" vacuum applied under the carb to draw air through. 2bbl carbs are measured in the same way but with 3.0" of vacuum applied.
sreZ28
Oct 22, 2015 08:21 AM
Dragonsys
Sep 25, 2015 03:51 PM
