Air Cleaner Question...
Old May 21, 2002 | 07:36 PM
F-B0DYCAMAR0_83's Avatar
Whats the better setup for my 305 4 barrel?
1. Stock setup with the single intake.
2. Stock setup with the double intake.
3. Open air element.
4. A "Ram Air" setup
If Ram Air is the way to go, is there a way to setup a system on my 83?
Mike
Old May 21, 2002 | 09:39 PM
TBI305Camaro's Avatar
id just go with an open element, cheap and effective
Old May 21, 2002 | 10:01 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
open elemet - for the same reasons as above
Old May 21, 2002 | 10:41 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well, I have a like new 84 Z28 duel snorkel for sale.
Auggie
Old May 23, 2002 | 11:49 AM
Damon's Avatar
You can start with a 14" open element and then add on a cold air/ram air system as time and money permits.
I added a dula snorkel cold air system to one of my Malibus that came from here:
www.ramairbox.com
They have many systems available. The one I bought fits AROUND a standard 14x3 open element setup and was of generally high quality although it took some "modification" to clear the large HEI distributor.
Old May 23, 2002 | 01:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The factory-type snorkel is good for a daily driver, especially with temperature extremes. Cold weather, the thermovac helps avoid that off-idle stumble as the engine is warming up. The single is a huge restriction, though, so the dual is the preferred setup.
Hot weather, stop & go driving, the open element really suffers (at least, did for me). Either factory or the Ram Air ducted cool air really makes a difference.
I'm considering the Ram for the '57, since it only has open element right now, but they are pretty proud of their product.
Old May 24, 2002 | 08:08 AM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
I have the same setup on my '83 T/A. Can anybody recommend a place to buy the open air element? I already have the 14" K&N filter...
Old May 26, 2002 | 09:44 AM
your local autoparts stores
Old Jun 10, 2002 | 11:21 PM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
right now on my 83' Z-28 i have a spectral performance nine inch open element and i actually gaine like 4 hp from it after putting it on and taking off the air dam on the front by the bumper in the engine bay, my car also runs cooler for some reason
Old Jun 12, 2002 | 04:03 PM
1987fbd's Avatar
Hmmm!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
edoff13
Sep 11, 2015 03:55 AM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
