no pull with secondaries open
Car: 1983 Z28 Clone
Transmission: TH350
hello... i've set my a/v tension to about nothing ..soo that i get a huge bog when i mash it................(on purpose) now ..on my monte when i do this.... it bogs super bad ..and then SLAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMMMM!!!!!!...you get shoved in the back seat.............when i adjust it like that on my camaro... nothing ..it just bogs ..and goes on as normal...
adjusted for testing purposes....
whats the deal..?? i mean i used to hear all the air SUCKING ....in the monte.. but not in the camaro.... it just seems like the motor is reving high ..and thats it .. no pull...
any suggestions...... the lockout tang is removed also...and i have the choke wired open....dual snorkel....
thanx
rob
thanx
rob
Transmission: 4L80E/4L80E
You're probably experiencing the differences between the choke pull-offs, since they also affect AV opening.
Just adjust it the way it's supposed to be, and don't worry about it.
Car: 1983 Z28 Clone
Transmission: TH350
ok ok ok ............ ill put it back..... its just ... the car doesnt give you that ...feeling ..like its pulling ...more like your just coasting ...AT WOT..
oh well..
thanx man
rob
oh well..
thanx man
rob
My car felt similar to what you are describing. My problem turned out to be the timing. The lighter springs in my distributor were allowing the weights to swing out while at idle. So when I set my base timing it was already advanced and no additional advance was available at higher rpm. This made it feel dead above ~3500 rpm. Just mentioning this to give you another possibility to rule out. Make sure your total timing is reaching ~32-36 degrees by 2800 rpm. Makes all the difference!
Car: 1983 Z28 Clone
Transmission: TH350
GOOD POINT..!!! I HAVE A CURVE KIT..... i just used the stock weights and center peice...but used the LIGHTEST SPRINGS POSible.........
ill check it out..............................
thanx.. ill let you know how it works tomarrow.......ill switch to medium springs..
rob
rob
My car liked the DR rods, even when stock, vs. the CH's.
mdtoren
Aug 16, 2015 05:45 PM
