Carb with O2?
Old Aug 5, 2002 | 03:37 AM
RS91's Avatar
Carb with O2?
If I switch from TBI to Carb, will my O2 sensor matter. Do I have to change it if my 02 is bad. What are the effects if my 02 is bad on a car with a carb.
Thnks..
Old Aug 5, 2002 | 10:25 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Assuming you go the typical non-CC carb route, the O2 sensor will become a plug in the hole in the header. No function anymore.
Old Aug 5, 2002 | 11:06 PM
RS91's Avatar
Thanks...
Old Aug 6, 2002 | 09:19 AM
Max's Avatar
Max
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
You can use is it to provide great tuning feedback through the use of a air / fuel ratio meter. I just did a similar swap and then installed an Auto Meter air / fuel ratio gauge. It has really helped me dial in the fuel curve on my new Holley 670. There is no more guess work. I can maximize power without wasting fuel by running to rich. The gauge is fairly cheap and easy to install.
A lot of people told me that a 670 would be too much carb for my 305 but with some fine tuning the thing runs awesome. No regrets whatsoever.
Old Aug 6, 2002 | 09:42 PM
RS91's Avatar
Thanks for the tips...
Old Aug 6, 2002 | 10:01 PM
jfox55's Avatar
my car is non computer controlled, you mean I can just plug the a/f ration gauge scensor into my o2 scensor hole and that works great. If so, I will be picking one of these up soon.
Old Aug 7, 2002 | 09:17 AM
Max's Avatar
Max
You can use the existing oxygen sensor. Since you already have that the only cost is for the gauge and something to mount it in. I think the Auto Meter setup I bought cost me about $75. To me eliminating all of the guess work in tuning was well worth the investment.
Old Aug 7, 2002 | 09:49 AM
ronterry's Avatar
Car: '94 Corvette
I wouldn't say eliminates the guess work.
Reading the plugs are going to give you a look at how the combustion is going over a period of time.
While the O2 is going to tell you with some slop if you’re running lean or rich.
Mine was quick at detecting a lean spot off idle, so they do have there uses with tuning.
Would I say an O2 is worth it? It certainly was more appealing than some other options getting in to the 100's & even 1000's of dollars...
Ron
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
