do i need a return spring?
Old Aug 16, 2002 | 10:33 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
hey gusy i have a edelbrock 1407 carb. it has a spring on it already and pulls itself back but i was wonderin if i need to have a seperate return spring that hooked to the carb then to a bracket onthe manifold or sumtin? if any1 can help i would be very thankful
Old Aug 17, 2002 | 12:00 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Are you sure it already has a spring?
Old Aug 17, 2002 | 12:12 AM
Car: 89 Formula
Engine: Carbed 5.7
yea its liek on the shaft the linkage is on. it likes wraps around it. my dad said don;t put a spring on because it will make my pedel real hard. wut do u think
Old Aug 17, 2002 | 12:24 AM
Jester's Avatar
Yes...you do. In fact...you need 2 At least to be legal at any track...and it's not a bad idea anyway.
Old Aug 17, 2002 | 03:40 AM
ronterry's Avatar
Car: '94 Corvette
There's no way in **** you'll want to trust just using that shaft spring.
Get a good quality spring, and the pedal will not feel hard.
You can get one of those twin springs (one inside the other) for cheap.
I don't even think that shaft spring is a considered a return spring? I think it just gives the throttle shaft some tension.
Don't Q-Jets have the same deal?
Ron
Old Aug 17, 2002 | 08:45 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I had an Edelbrock carb on my last motor and that spring on it is not enough..you need to add another return spring.
Old Aug 17, 2002 | 08:47 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Ever had a throttle stick wide open while approaching stopped traffic or your garage back wall or the like? Ever watch footage of NASCAR wrecks where this happens, and people get killed when they hit the wall at 180 mph?
Now, do you think it's worth the $2 for an additional spring?
Old Aug 18, 2002 | 08:50 PM
84TAProject's Avatar
I'll admit I am guilty of only having one spring on my quadrajet, to give the pedal a lighter feel which gives me in my opinion better feel on when the secondaries are about to open. With them all stiff I was too busy fighting the stiff and would get socked when theyd open. At least now Im ready for the kick.
If running one MAKE SURE its in good shape. When I first got my car running with the 305, I hit WOT and had it stick open and that was extremely scary, going 50 on that back road and pulling still. Had to put it in nuetral and turn it off. Only had one spring, and it was weak, and wouldnt return it.
Old Aug 19, 2002 | 11:54 AM
Car: 89 Formula
Engine: Carbed 5.7
alright well i got a double spring and my pedel in fine and it return it perfect from WOT when i do it with my hand so i am good.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
87v6Bird
Jul 1, 2018 04:12 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
sandman92084
Sep 12, 2015 10:27 PM
