Dumb Question Regarding Air Valve?
Old Sep 2, 2002 | 02:22 PM
Trevor K's Avatar
When the tech articles state to adjust the air valve, I can locate the screw and that. I assume the 'air valve' is the big flap on top of the secondaries?
And I adjust the screw until it snaps shut on it's on, leave it, drive it for a bit, and if it bogs off the line it's wrong right?
The reason I'm asking is because I did this and assumed the flaps were the 'air valve'. I don't know why, but now I have a bit more wheelspin off of the line it seems (I know, might be all in my head).
I g-teched my car before, got a best of 15.71 @ 92.5MPH. Now I get a 15.9x @ 91.6MPH. On my runs before, after playing with the G-Tech, I realized wheel spin was bringing the times up. When I do my runs now, to get my best results I just punch the gas (no brake torque). The conditions on the runs were not idential (10-15 deg. Celsius difference), so I'll need to do more testing. I'm thinking my times went up because of increased wheel spin?
Old Sep 2, 2002 | 03:35 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes, that is the air valve.
Adjust it so that it has about 5/8 turn of tension. That is, loosen the set screw, let the blades go slack, tighten them until they just get held closed by the spring, then 5/8 turn more, and tighten the set screw. Experimant from there for best results (best power, with no Quadra-Bog)
Old Sep 2, 2002 | 11:33 PM
Trevor K's Avatar
So undertightening will give me a bog, and overtightening will make my secondaries take longer to open, correct? Will the bog be easier noticeable when I step on it?
And the 'set screw' is the one behind (that takes a flat blade screwdriver) the metal piece that the air valve rod sits on?
Old Sep 3, 2002 | 08:48 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
The air valve has two screws. The flat bladed screw is the adjustment.
The set screw is screwed in from underneath in the same area. It's a small (T-10 I think) Torx screw.
I've had best results at tightening it with a 1/4" wrench and a screwdriver bit.
Old Sep 3, 2002 | 11:35 AM
Trevor K's Avatar
So I adjust it using the 'set screw'? If so, then what is the adjustment screw for?
Old Sep 3, 2002 | 11:36 AM
99Hawk120's Avatar
No, the set screw is what HOLDS the adjustment.
Loosen set screw, tighten the adjustment screw, tighten set screw or it WILL loosen by itself.
Old Sep 4, 2002 | 12:10 AM
Trevor K's Avatar
And the set screw is going to be something underneath I'm basically going to have to feel around for (since I won't be able to see it with the carb on)?
Old Sep 4, 2002 | 08:12 AM
99Hawk120's Avatar
Pretty much. Or get a small dentist's mirror...
I know where it is and even I have trouble finding it sometimes.
Old Sep 5, 2002 | 08:58 AM
Trevor K's Avatar
I think I saw one of those in a flyer in the paper for like $2, I think I'll pick that up..
So is the purpose of the set screw to hold the adjustment screw in place (Like it screws up against the adjustment screw)? I don't have a blow-up diagram of the carb, but I'm curious as to it's function...
1992 Trans Am
May 10, 2023 07:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
