DP vs 4160
Old Nov 18, 2002 | 01:14 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
DP vs 4160
DP vs 4160
Whats the advantage of running a holley double dumper, or avenger over a regular 600 cfm 4160 carb. How much power difference is ther in power, which is better, how bad will gas mileage suffer?
Old Nov 18, 2002 | 01:57 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
if you have a idea of what you are doing don't get the street avenger. When I first got it It was great....out of the box tuning was on the money but you can build your own cheaper with new holley parts and save 100.00 I will next time.
I like the DP for the 4 corner idle but its not that good with a auto, however that is not to say you would not have success runing it on a auto. Gas milage will be better on any Vac. secondary carb.
Brian
Frozer!!!
Jan 19, 2024 04:55 PM
pont82fbird
Carburetors
Jul 26, 2003 11:57 AM
1982Camaro383
Carburetors
May 5, 2003 08:47 AM
1982Camaro383
May 5, 2003 07:03 AM
chymos
Mar 7, 2003 09:38 AM
