does this wire go here
Old Dec 28, 2002 | 11:08 AM
mypurple92rs's Avatar
Car: 86 iroc
Engine: 350 carbed
Transmission: t5
i'm 99.9% sure this green wire hooks up to my choke but it the .1% that scares me thanks in advance
btw it a eldrobrock 750
Old Dec 28, 2002 | 11:24 AM
flyway190's Avatar
Yes, that wire goes to the electric choke.
Old Dec 30, 2002 | 07:39 AM
82-T/A [Work]'s Avatar
Does the green wire always mean electric choke? I have a green wire in the engine bay of my 1981 TransAm, and I have yet to hook up the choke yet, actually.. I have yet to re-install the front fenders and nose too, but that's another post.
Todd
Old Dec 30, 2002 | 01:20 PM
flyway190's Avatar
Not always, I believe the coolant temperature sender has a green wire also. It's the connector that gives away the choke wire.
Old Jan 2, 2003 | 10:25 PM
ThirdGen Stoner's Avatar
MyPurple92rs, you are ***. I was about to ask if I could use my stock electric choke wire on my new Eldeldbrock. BTW we have the same carb. I hope you have good luck with yours. I plan on starting mine by monday!!
PS: What motor did your car come with stock? Because I have that same exact wire in my car. And my stock motor was a LG4.
(Just thought it was ironic that we prolly had the same stock motor and have the same aftermarket carb....):lala:
Old Jan 3, 2003 | 12:02 PM
Car: 86 iroc
Engine: 350 carbed
Transmission: t5
yeah it was the lg4 dog at one time nows it a 73 350
btw i hooked the wire up at the choke worked like it should (thanks flyway) now i just have to get a good book on how to fine tune these things and a supercharger 12 bolt 6 speed nos opps there i go day dreaming again
gl with yours stoner
Old Jan 3, 2003 | 06:43 PM
1982chevycamaroz28's Avatar
hey thirdgenstoner u dont need a 750 cfm carb on ur lg4 motor. thats too much for that motor. i know becuz ive asked before and people told me go with the 600 cfm and id be happier with it. and if ur motor is stock then the 750 is way too much for it and all ull be wastin is time and money.
Old Jan 5, 2003 | 09:42 AM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Does that green wire that hook up to the Choke depend on the Computer to operate or is just a hot lead wire. I have disconnected the computer from my car and my Avenger Carb has the electric choke.
Old Jan 5, 2003 | 12:01 PM
Damon's Avatar
No, it's just hot anytime the ignition is turned on. It might also require that there be oil pressure present to send current. There's a relay for it and a fuse and other stuff- it's more complicated than earlier non-computer controlled QJet setups. However, despite the added complexity none of that is hooked to the ECM or requires input from the ECM to operate.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
