stalling when car is cold!!!!!!
Old Jan 6, 2003 | 01:15 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
I dont remember much about these stupid electric choke deals,,,but I hear they dont work half the time. My problem is in the summer my car always stalled if it wasnt warmed up. It never stalled last year in the winter (the choke i guess would kick in and idle the car up) but now this winter the car wont stay running when cold either. The car seems to run perfect when it is been runnign for about 5-10 mins or so. I dont want to screw with the choke incase I mess up anything thats already working right, follow me??? How can I test to see if my choke is working,,,,plus what can I do if it is not working...as it looks like its rivited to the carb.
oh ya when I start the car it seems to want to idle up but it will slowly drop in rpms untill it bogs itself out,,,,,I either have to intermitanly give it a shot of gas,,,because just trying to hold it at a sertain rpm like 2500 to it will bog out too,,,,,and if I got the car in nutral and let the clutch out the car will bog out a bit easyier. Can anyone help me with this problem,,,,it is my choke right??
Plus a few of my sensors are gonne and my engine light is on,,,does my choke (know that),,,,do the sensors affect the operation of the choke?.
Oh my,,,thats a mouth full....Thanks if you can help!
Old Jan 7, 2003 | 02:05 PM
FRDH8R's Avatar
I would like to know some info on this topic as well, my car does the exact same thing! and I know it's the choke, can anyone help?
Old Jan 10, 2003 | 05:06 PM
FRDH8R's Avatar
bump, can anyone help!
Old Jan 10, 2003 | 05:11 PM
FRDH8R's Avatar
Old Jan 12, 2003 | 01:12 PM
Car: '81 Trans Am
Engine: 6.6L
anyone????
Old Jan 14, 2003 | 04:03 AM
maverick351ci's Avatar
Car: 1985 Firebird
ok as far as setting the choke hears what you do
at 70 degrees F the choke should be at about a 45 degree angle if its way cold out warm your car up to operating temp set the choke so it just is barly on if your doing it when its cold set it to have about a 1/4 opening then get your car warm and see where its at see if it opened up
hope this helps i set a lot of them this way and it works like a champ but you my have to play with it a lil bit to get it perfect witch it will never be but dont worry about that
LATER
Old Jan 14, 2003 | 04:06 AM
Car: 1985 Firebird
just seen that yours is rivited that means your carm has never been gone trough you can adjust this 2 ways you can get a choke kit or a rebuild kit knock out the rivets and the kits have screews to replace them or you can take 2 neadle nose plyers and bend the rod a lil bit
Old Jan 14, 2003 | 04:09 AM
Car: 1985 Firebird
as far as your ses light take a paper clip put it in pins a and b should be the top right corner your ses will flash a code like for instance (light on pause light on light on = 12) that is the code for no codes code 13 is egr just post your code here and i will tell you how to fix it
Old Jan 14, 2003 | 08:33 AM
82camaro's Avatar
Car: 82 camaro SC
First, is it running too rich when it stalls or to lean. Rich will blow black smoke out of the exhaust--and may indicate the choke pull-off isn't working correctly. First thing in the morning, pop the hood and remove the air cleaner. Open and close the throttle one time. This should close the choke and set the fast idle. Now, have someone start the car. The choke pull-off will partially open the choke once the engine is running--if it doesn't, the choke pull-off is broken, or the vacuum line to it is broken. Once you get that working, then drill out the rivets and adjust as needed. The choke system on carbs work, but not perfectly.
Old Jan 14, 2003 | 10:02 AM
Car: '81 Trans Am
Engine: 6.6L
Originally posted by 82camaro
First, is it running too rich when it stalls or to lean. Rich will blow black smoke out of the exhaust--and may indicate the choke pull-off isn't working correctly. First thing in the morning, pop the hood and remove the air cleaner. Open and close the throttle one time. This should close the choke and set the fast idle. Now, have someone start the car. The choke pull-off will partially open the choke once the engine is running--if it doesn't, the choke pull-off is broken, or the vacuum line to it is broken. Once you get that working, then drill out the rivets and adjust as needed. The choke system on carbs works, but not perfectly.
Right on man thanks,,,Ill cheack that out!! Can you point out were the choke pull off hose is. Is there a rod or somthing on the side of the carb or is it just run by vacum line??? I posted a pic below hopefully you can point it out to me,,,,,(like circle it or something and post it again). I can almost bet this is my problem. All I realy need to know is how can I fix the choke pulloff if it's not working. I know my problem is my choke but I still have this problem on the hotest day of the year where I thought my choke doesnt need to function,,,so thats why I thought it needed more then just some adjusting......Right???
Old Jan 14, 2003 | 01:41 PM
82camaro's Avatar
Car: 82 camaro SC
This is it.... Vacuum should cause that to move and open the choke slightly. Also, verify that you have 12 volts at the choke when it's running. What would also really help(once you verify the choke pull-off is working), is: when it stalls and runs poorly pop the hood and look at the choke--is it open or shut?
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
drathaar907
Aug 6, 2015 04:20 PM
