Removing Carb...Got a question..
Old Jan 6, 2003 | 04:24 PM
BillZ28's Avatar
Car: 84 Z28
On the throttle lever there are two cables attached to it. One, on the outer most part is big and was easy to remove, however, there is a smaller cable on the inside part. Is this for the cruise control? How do I remove it?
Old Jan 6, 2003 | 04:26 PM
BillZ28's Avatar
Car: 84 Z28
And also there is a big line running into the Q-Jet in the rear near the base of the carb. What's this?
Old Jan 6, 2003 | 05:01 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
pcv or brake booster vacum source...
Old Jan 6, 2003 | 05:25 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
The small cable sounds like the TV cable for the 700R4 trans. Push it forward to disconnect it.
Other is brake booster source like fb305svs says.
Andy.
Old Jan 7, 2003 | 12:39 AM
fb305svs's Avatar
on my 86 lg4, the brake booster vacum source was from a direct tap into the manifold, not the carb from what i remmeber- and the pcv line was biger than most as i remember... just trace the line, and see where it leads.
Steve
Old Jan 7, 2003 | 09:37 PM
SkyWarrior's Avatar
Car: 1986 Pontiac Trans Am
Engine: 305 LG4
Transmission: Borg Warner 5 Speed
the big outside one is for cruise control, the one on the inside is for throttle pedal, thee huge (metal vacuum line in the rear is for power brake booster.
Old Jan 7, 2003 | 09:44 PM
BillZ28's Avatar
Car: 84 Z28
Ok. Will I need to hook that power brake booster up to the new carb? The Holley doesn't have a plug for it in the back where the QJet does.
Old Jan 7, 2003 | 11:48 PM
fb305svs's Avatar
the power brake booster line should remain hooked up to the intake vacum source, not the carb if its initially set up that way.
Steve
fb305svs's Avatar
Steve
Old Jan 8, 2003 | 08:02 PM
BillZ28's Avatar
Car: 84 Z28
OK and I have another question. Some one told me since I don't have emissions I could get the Performer Intake Manifold #2101 that doesn't have the EGR provisions. So when I go to put it on can I just put it on or do I have to plug anything in the heads?
Old Jan 8, 2003 | 11:20 PM
fb305svs's Avatar
i have the emmisions legal performer intake.... with the block off plate thats included with it installed. thats all you need to do, nothing to block off in the heads or whatnot.
Steve
Old Jan 9, 2003 | 06:08 PM
BillZ28's Avatar
Car: 84 Z28
Steve
Is that the big opening behind the carburetor bore on the intake manifold?
Old Jan 9, 2003 | 06:33 PM
flyway190's Avatar
Whatever you do be careful with that TV cable clip. You'll be very sorry if you break it.
Old Jan 9, 2003 | 06:43 PM
BillZ28's Avatar
Car: 84 Z28
I did manage to get the TV cable disconnected from the carb and the carb is off. I have no idea how I got it off though.
Old Jan 9, 2003 | 07:24 PM
fb305svs's Avatar
yes, that is what that is on my car. Be sure to have the special filter/backfire blocker installed- if you have a backfire through the intake, you will damage your brake booster and need a new one.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
