Getting a CCC to run richer...
I think my CCC is running a little lean, as when I pulled a head, my exhaust valves were very white. I have the CCC on the setup below for the trans am, and am clueless as to how to richen up the normal part of driving. I still have a bone stock ECU.
Transmission: 4L80E/4L80E
Sounds like it's running just like it should. No burnt valves, right?
I dont think there was any burnt valves, I dont know all that much about it, but my father saw the valves and just commented that it looked like it was running lean because of white exhaust valves. The valves looked fine, except the intakes were black, and the exhausts white. The intake valves had some carbon build up on the back of the valve, but I tried as best to scrub it off with a wire brush and kerosene before putting them back on. I had to pull the head due to a broken valve that mushroomed over at top, and managed to stay in the keepers. The plugs looked fine according to a chart. So it should run fine on a mild 350 (albeit one much more nasty than the LG4) with the stock ECU at part throttle/normal driving then, right?
Maybe, maybe not. Some say yes, but ever since I swapped my engine my car runs so lean at part throttle that it pings. I've been trying to get a hold of a different chip to try, but don't have one yet.
Ben
Originally posted by Momar
Have you adjusted anything? Does it do this in open loop, closed loop, or both?
Ben
Ben
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
Street Lethal
Aug 13, 2015 08:28 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
