Non CC carb, what distributor
Old Jan 29, 2003 | 04:02 PM
Z-Man 85's Avatar
Since i got my engine rebuilt in my Camaro, i have been trying to learn as much about poformance and going fast as much possible. My Camaro (85 Z28 Lg4) had the stock cc carb before the rebuild. Now it has an Edelbrock carburator, along with edelbrock intake, headers, and a mild cam. I was going to buy an Accel distributor, but a guy at Checkers told me that I should just keep the old distributor i had in it, which is the computer-controlled one because with the Accell i wouldn't be "able to time it right"
Does this guy know what hes talking about? I don't have any of the old sensors hooked up, so how does the computer get the right information to know when or how much to advance it?
should i get the Accell?
Old Jan 29, 2003 | 05:50 PM
fanman's Avatar
As I understand it, you'll need to get a non cc distributor, in order to get some advance. I think that the computer gets it's info from the carb..on when to advance the timing. Instead of buying a new unit, you could get one from a junk yard and recondition it (which is what I am doing).
I'm still learning, so some of this info could be wrong.
Old Jan 29, 2003 | 08:31 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
yea, you have to buy a vacuum advance dist. the one on the stock lg4 is comp controlled....
Old Jan 29, 2003 | 09:51 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
If you are running a computer controlled distributor with a non CC carb your car will be getting NO advance ...its probably like driving around a 3-cylinder Geo filled with concrete.
You could just get a vacuum advance GM HEI distributor out of a junkyard and it may just suit you perfectly but if you are looking for all out performance go with an MSD Pro-Billet. The Pro-Billet is a bit pricy but I feel its worth every penny.
Old Jan 30, 2003 | 02:01 PM
Z-Man 85's Avatar
Thanks! that is exactly what i wanted to hear!!
Old Feb 3, 2003 | 07:18 PM
Firebird355's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
how would you hook up a hei with vaccum advace and maybe a picture of wires because all my wires are just laying off to the side of my car right now..
Maybe if someone knows what wires i need to keep to make the motor run, charge, and maybe for the gauges...
thanks alot
Old Feb 4, 2003 | 08:55 AM
Z-Man 85's Avatar
what carb do you have?
I'll try to take some pictures of my 'birds connections when i get home from work.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
customblackbird
Oct 1, 2015 04:30 PM
camarohelp
Sep 22, 2015 03:19 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
Jlanz55
Sep 6, 2015 03:05 PM
