600cfm
Old Jan 31, 2003 | 09:41 PM
trans_am_ta_84's Avatar
Car: 89 trans am
Engine: 355
600cfm
i have a pretty much stock 305 other then an intake and carb. i put a holley 600cfm 4 barrell on it. the chock fuses kept blowing so i took the choke out. it loads up is it cause too much carburation or cause i need the choke. and any suggestions to how i cold fix the fuse problem?
Old Jan 31, 2003 | 09:50 PM
Boxeat2469's Avatar
What do you mean by "you took the choke out"? If you just disconnected the electrical connection then that could be your problem. If the choke is staying closed all the time that would cause the car to run too rich.
Old Feb 1, 2003 | 02:29 AM
Car: 89 trans am
Engine: 355
took the choke out meaning there is no more choke
sreZ28
Oct 22, 2015 08:21 AM
Scorched1984
Sep 15, 2015 03:42 PM
83_TA
Carburetors
Jul 11, 2001 03:50 PM
Holland
Carburetors
May 15, 2001 04:21 PM
86TpiTransAm
Carburetors
55
Mar 28, 2001 11:54 AM
