Need Imediate Help! please
Old Feb 15, 2003 | 07:28 AM
86FirebirdV8350's Avatar
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
I bought an edelbrock 600 cfm carb yesterday (1406 model) the carb I have now is a cc rochester quadrajet with electric choke...The edelbrock also has an electric choke but no where to plug the other 2 wires in because its not computer controlled, can I just keep these wires detatched and hide them or would something not work right??? please help because I wanna put it on today
Old Feb 15, 2003 | 11:13 AM
1986redbird's Avatar
no, you can't, the distributor timming is controlled but the computer which gets some of the data it needs from the carb. (I.E.--throttle position), and if you have an automatic with overdrive then the lockup in the tranny will not work.
if you want to switch to a non computer carb then you will have to replace the dist. and come up with a way to lockup the torque converter manually.
Old Feb 15, 2003 | 08:58 PM
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
umm....i unplugged the carb to see if it would hurt anything....everything worked fine, so proceeded with the swap...bad idea???
Old Feb 15, 2003 | 09:02 PM
did you drive the car after unhooking the carb? I'll bet the performance is WAY down because the timming won't advance.
Old Feb 16, 2003 | 02:41 PM
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
Of course I drove it, drove the same as it did without it, i put the edelbrock on today...looks like everything works fine
RedLeader289
May 28, 2019 01:47 PM
MY87LT
Carburetors
Sep 25, 2013 11:48 AM
Twessing
Aug 3, 2013 12:07 AM
AJHECK95
Oct 17, 2012 08:51 AM
Camaro_hunter_d
Apr 1, 2001 02:10 PM
