after 350 swap car wont run
Old Oct 16, 2012 | 10:38 AM
AJHECK95's Avatar
Car: 1989 formula
Engine: stock lo3 305
Axle/Gears: dont know
i put a carbed 80s 350 in my car swapped intake to a weiland 8004 and now i cant get it to stay running. it starts then dies imediately, no clue whats going on ran perfect before i put it in anything will help.
Old Oct 16, 2012 | 11:18 AM
7thdarkangel's Avatar
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
Re: after 350 swap car wont run
any vacuum leaks?
Old Oct 16, 2012 | 11:19 AM
AJHECK95's Avatar
Car: 1989 formula
I can check, i currently am running a qudrajet carb, wieland intake, msd wires and headers and thats all thats done to the engine besides a stock rebuild
Old Oct 16, 2012 | 12:45 PM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
let me know about the vacuum lines. make sure any unused ports are capped. i just finished a 406 sbc build and got pissed off when i could not get it to idle. found i forgot to reconnect the brake booster so the intake vacuum was unplugged. fixed that and it runs mint.
Old Oct 16, 2012 | 12:52 PM
AJHECK95's Avatar
Car: 1989 formula
I will check that when i get off work, hopefully thats my problem
Old Oct 16, 2012 | 01:24 PM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Did you kill vats?
Old Oct 16, 2012 | 01:31 PM
AJHECK95's Avatar
Car: 1989 formula
i dont know, but just to see if any of that was messing up i ran a wire straight from the batteries positive to the coil and it did the same thing
Old Oct 16, 2012 | 02:09 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Whats your timing set at?
Old Oct 16, 2012 | 02:22 PM
AJHECK95's Avatar
Car: 1989 formula
havent been able to check yet wont run long enough, i put the distributor back in the same place it was. i marked the rotors location on the firewall when i pulled it out to swap intakes put it back together and no dice.
Old Oct 17, 2012 | 06:28 AM
TTOP350's Avatar
Sounds like your timing is off to me. Rotor on firewall, check. Did you mark rotor postion on the base of the dist also?
Old Oct 17, 2012 | 08:51 AM
AJHECK95's Avatar
Car: 1989 formula
Update i got it running after i blocked the vaccum port on the bottom front of the carb, and turned my distributor a little bit. But now it wont idle. i think i just need to time it and adjust the carb
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
gwade12
Aug 8, 2015 08:17 AM
