using L69 carb on Lg4
Car: 1985 Berlinetta
Engine: 305 4BBL
I just got a carb from an 84 L69. It is computer controlled. Will this work with my LG4? What adverse effects will this have,if any?
thanks
thanks
Engine: 305 4BBL
Is the L69 going to use more gas, less gas, cause a stumble or any other flubs. Will I need to change the metering rods or run with them?
The L69 Carb is a good piece, most people go with metering rods alittle richer. I am currently upgrading to DR Rods and B Hangars, most people say tha is the best well rounded rods fo that little extra juice. Myself having a High alt/Cali carb would definatly appreciate the added fuel.
Go for it, it won't cause a mileage change as most of the fuel load is in the secondary's
Re: using L69 carb on Lg4
thanks
thanks
You will notice a significant performance increase - assuming the L69 carb is in decent shape. No idle, part throttle, or emissions problems should occur due to the primary side being identical. The only time you'll use more gas is when the secondaries open!
Engine: 305 4BBL
More info
I pulled the L69 carb out of the box today and looked at the hanger and rods. It is a K hanger and CH rods. Being a total carb idiot (I do know where they go and how to bolt them on!), is this a good combination for a rebuilt but stock 305?
I know a little more about Holleys and Nothing about CC qJets.
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
Damon
Sep 26, 2015 04:29 PM
