Tuning Holley's at the track.
Old Mar 8, 2003 | 11:33 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
I must say, I'm really impressed with how easy they are to mess with while your there..(at least in the day time)
i was down atco today for only the second time with my Z28 with the new combo in it.. last night was the first.
While at the track over the past two days.... i've changed jets 4 times, and the secondary spring 2 times.....
It really doesn't get much easier than that, not really overly messy.
it was way way lean on me. so i jetted the secondaries up.
still lean, they went up some more. finally it was somewhere close, and i was rewarded with an extra mph in trap speed
just nice dealing with something so blatantly simple.
new best times for the car. 12.54 @ 109.96
Old Mar 9, 2003 | 02:22 PM
Jester's Avatar
great times bro. Keep at it to..might be another mph in there somewhere too.
Old Mar 9, 2003 | 07:35 PM
Car: 1986 Z28
Engine: 355
Transmission: th400
i'm sure theres another few mph's hiding in there. just a matter of fine tuning and finding them... i really havne't even started tuning it yet.. just feeling it out.
Old Mar 15, 2003 | 09:36 PM
Rancid87's Avatar
That carb has come a long way since its initial fireball shooting days! Nice to see it's working out for the best (o:
Old Mar 19, 2003 | 01:59 AM
Mandangelo's Avatar
Car: 89 IROC
Engine: 350 Carbed
Transmission: WC T5
PonyKiller
What's under the hood ? Im looking for similiar times from my 89 IROC.
BC
Old Mar 19, 2003 | 02:06 AM
black84-6spdz28's Avatar
he has something similar to mine...
vortec heads
xe 274h cam
rpm intake
pony killer...what carb you using?.....
Old Mar 19, 2003 | 09:07 AM
Car: 1986 Z28
Engine: 355
Transmission: th400
Why thank you rancid.. it's much friendlier on the feet and eyebrows this way.
i've been monkeying with the jets and now have it jetted 80-86 it seems very close.... i'll go richer or leaner this coming week i guess. no pinging now. i'm coming through the traps right on the rich stoich line on the af gauge.
Best time with it now, is a 12.28 @ 111.37. that was last friday.
last night i was hitting conistent 12.32-38's @ 110.2-.9's
by the end of the night i was launching hard enough to uncover another lil tuning bugabo.
When i launch very agressivly the suspension unloads really hard. Nose comes up. and carb starves for gas. motor cuts out momentarily. i thing i've gota bring the float levels up some.. I set them low initially. so i'm going to bring em up and give it a couple more shots...
it's hard to duplicate though the odds of the track biting that hard on a friday night are slim
i was getting 1.73-6 60ers on all the 12.3 passes.
the last two were the best. when it cut out on me, also the two quickest passes of the night.... get that straitened otu.. and a couple ticks should shed at the top end as well.
if the bowl level doesn't cure it, i'll have tor un jet extensions or something.
As for as combo, here's the quicky
350, Vortec heads, bowl work, rpm intake, stock vavles, 10.7 compression 1 3/4 slp headers, 700R 3300 9.5" act converter,3.73 ten bolt, and cheaters.
Carb is a very old. 3130 holley. 780 vac sec. OE from like a 65 imp or something.
Old Mar 19, 2003 | 04:13 PM
Craig84Z's Avatar
Car: 1984 Camaro Z28
Engine: Blueprint 383
Pony Killer,
What carb were you running? If this is a different carb, what times were you running with the other carb?
Thanks,
Craig
Old Mar 19, 2003 | 04:23 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Fuel may be sloshing out of the bowl vents on a hard launch.
Try joining the bowl vents with a piece of vacuum hose.
Snip a hole in the top and tie wrap it to the carb stud.
Old racers trick, along with the jet extensions.
Old Mar 27, 2003 | 09:00 AM
gtabadboy's Avatar
Please look at my monster combo and tell me why I only run a 13 flat. I know I may need some carb tuning. The carb is 2 months old... any suggestion on jets or even a new carb??
Old Apr 1, 2003 | 05:05 PM
Car: 1986 Z28
Engine: 355
Transmission: th400
sounds like you need to do some all around tuning there gta...
carb, timing, and suspension... that should definitly be going faster.
what's your whole timeslip looklike
Old Apr 1, 2003 | 06:20 PM
gtabadboy's Avatar
Got the BFG street slicks in attempt to help traction issues.
timeslip:
R/T .810
60' 1.882
330 5.425
1/8 8.398
MPH 82.67
1000 10.972
1/4 13.159
MPH 102.71
Old Apr 2, 2003 | 09:44 PM
Car: 1986 Z28
Engine: 355
Transmission: th400
where's your timing set at, and how's the carb setup
Old Apr 3, 2003 | 08:31 AM
gtabadboy's Avatar
Timing is about 10deg advance base and 36 total at 2500 RPM. The carb has not been jetted. Just A/F with an air fuel meter. Idle is about 1100 in park.
RaverRacerX
Mar 17, 2026 01:49 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Nervous2
Oct 8, 2015 10:53 PM
RedLeader289
Sep 23, 2015 06:50 AM
BBSDesigns
Sep 22, 2015 03:08 PM
