choke went out
Transmission: 4L80E/4L80E
Sure, as soon as you tell us exactly what you mean by "went out".
Car: '82 Z28
I wouldn't think you'd need a choke in Mesa
Is there power getting to the choke housing?
Is there power getting to the choke housing? Thread Starter
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
surprisingly, i do
. I think there is still power going to it, i'll have to check. Also, can i just get a new one? I heard something about getting a new cover so that it's adjustable? Just throwin out ideas
. I think there is still power going to it, i'll have to check. Also, can i just get a new one? I heard something about getting a new cover so that it's adjustable? Just throwin out ideas Joined: Mar 2000
Does the butterfly go shut when the engine is cold and the throttle is tapped? Does it go shut but not open up when the engine warms up? Which way does it "not work"?
That could be gummed-up or jammed choke linkage, or a broken choke thermostat bi-metal spring.
MikkoV
Sep 9, 2015 04:25 PM
