Open Element Questions
Old Oct 23, 2003 | 08:36 AM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Is the IAT sensor in the same place as the TBI setup? If it is I would need a hole in the base for the IAT sensor right? I plan on getting an open element so does it matter what kind of base I get. Drop or non-drop?
Old Oct 23, 2003 | 10:02 AM
92rsv8's Avatar
Car: 1992 camaro rs 97 yoyota camry
Engine: lo3 carbed
Transmission: t 5
are you switching to tbi??? because it says you have an 83 lg4...
a trick we tbi guys use is to get a flat base... it cost me 10 bucks new then put the iat in it. or you can set it where it gets cold air you can also get a resistor and splice it in. i can't remember the ohms it needs to be but you can do a search.
Old Oct 23, 2003 | 10:57 AM
anymethod's Avatar
Car: 1986 Trans Am
Engine: carb 305 LG4
Transmission: TH700-R4
Why are you getting an open element air cleaner when you have dual snorkel now? I learned about Clovis in western civ class yesterday. He was king of the Franks in like 650 AD in Europe. And now you live in his town
~Matt
Old Oct 23, 2003 | 03:11 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
No im not switching to tbi. it will be going on an 84 Z. Anymethod, I will be putting the open element on my 84 Z. The dual snorkel will stay on the 83 I learned about Clovis too in my west civil class! I was just wondering because this guy is going to sell me an open element from his tbi setup. It is a drop base and it has a hole in it for the IAT sensor. Do I need that same hole?
Old Oct 23, 2003 | 06:42 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Carb doesn't use IAT.
Old Oct 23, 2003 | 08:37 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Ok cool. What kind of drop base would you recoment or how much of a drop? I want to go with a 14x3.
Old Oct 23, 2003 | 09:44 PM
five7kid's Avatar
Depends upon the intake you're using. A slight high-rise like GMPP or Action + will fit under a stock hood with about 1-1/2" drop. Higher rise, need more drop. But, the more drop you have, the less space there is between the base and the air cleaner top.
Old Oct 23, 2003 | 11:38 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Right now I just have the stock manifold. Later down the road I will probably get an edelbrock performer manifold. Right now I just want something to fit under the stock hood. Should I get one with a slight drop?
Old Oct 24, 2003 | 01:29 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
I have a performer manifold (spread bore) with a spread >> square bore carb. plate with a holley 1850 carb... my holley drop base air cleaner clears the hood barely... so you should be fine with anything that has a slight drop
Old Oct 24, 2003 | 06:19 AM
92rsv8's Avatar
Engine: lo3 carbed
Transmission: t 5
if you are going tbi then do not get a drop base !!!!!!! read the "ultimate tbi mods" on this web site under the technical info!!!!! drop bases suck for tbi!!! also either port out and radius your stock tb or get a holley 670 cfm or turbo city model.
Old Oct 24, 2003 | 10:22 AM
five7kid's Avatar
92rsv8, a couple of things:
1) This is the Carburetor board you're on, you know.
2) Mike already said his is not going TBI. He is only considering using a drop base air cleaner that someone else previously had on a TBI, that he would put on an 84 - which would be carb.
Old Oct 24, 2003 | 10:44 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you left out #3.
there is NO PROOF WHAT SO EVER THAT IT MAKES A LARGE DIFFRENCE IN A TBI CAR.
thats only people going off "how it looks"
my drop base stock L03 is doing alot better then most flat base ones...... im not saying the drop base is better.. just saying it makes as bout as much diff as weather or not i take a dump before i get in the car.
Old Oct 24, 2003 | 11:00 AM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Ok, thanks for the help. I will look for one with a slight drop.
Mike
Frozer!!!
Jan 19, 2024 04:55 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
redmaroz
Aug 16, 2015 11:40 PM
wruiz
Aug 13, 2015 09:07 PM
