Building a 383....need some advice on carb/intake....
Old Nov 3, 2003 | 10:42 PM
KYL98's Avatar
Car: 1991 Z28
Im building a new 383 for my RS and need some advice on a carb/intake setup. Heres the lowdown on the motor...
.030 4bolt 350 block
Eagle 383 rotating assembly
Dart Iron Eagle 220cc runner (2.05/1.60 valves)
Comp XR276HR-10
Im thinking about the Edelbrock RPM air gap or Torquer II intake....but not sure about the carb. What would work well with my setup?? Its pretty much going to be a weekend toy....maybe an occasional strip pass, but otherwise a cruiser......thanks in advance.
Old Nov 3, 2003 | 10:50 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
OH I would suggest a Victor Jr port matched to your heads and
BG demon 750cfm carb with mechanical secondaries.
Old Nov 4, 2003 | 05:25 AM
Nozzghoull's Avatar
Car: 86 TA
Engine: 383 Stroker
I'm running a 383 stroker with the rpm air gap and holley street avenger 770cmf and love it. The cars a gas hog but I only drive her on the weekends so no big deal!
Old Nov 4, 2003 | 11:39 AM
chad89ta's Avatar
cool i got almost the same set up u do ive got a 355 with dart iron egale heads 215 cc, xr comp 274 cam with trw flat top pistons im runing the rpm intake with holley 4150 650 dp,the motor takes a lot of jet im runing 71,84 jet sizes so if i where you i would go with the 750 cfm with hooker long tube headers,true duel 3 inch best et 1/8 7.81 at 96 mph with 2.00 60 ft,
Old Nov 4, 2003 | 11:50 AM
KYL98's Avatar
Car: 1991 Z28
I was thinking of a Holley DP but wasnt sure how well it would work with the big intake runner of the Iron Eagles.... SHould I go with a single plane since Ill already be making big lower end torque?? My exhaust is the Hooker LT's with the 3in Mufflex Ypipe into a 3.5in Ipipe and Flowmaster Force II muffler. I should get the block back from machining in a few hours...then Im going to assemble it this week. My friend mentioned that I could use maybe a Edelbrock AVS series carb for street use...and get a Holley DP for track duties....or just to haul ***. I can get a rebuilt Holley 750DP for a reasonable trade from a fellow worker.....just not sure what route to go on the intake yet. Thanks for all the suggestions so far.
ps. what kind of numbers "might" I expect with a Holley DP and Victor Jr intake????? or something else similar......
Old Nov 4, 2003 | 12:04 PM
chad89ta's Avatar
i would go with the victor jr,just because of the 383,and i would go with the holley as well,ive benn using mine as a daily driver just because i cant go without the power,with that set up i would think with a good 60ft time like 1,70 or better you car would run high to mid 11s,if you would like email me at provgolf4u@aol.com
Old Nov 4, 2003 | 12:06 PM
chad89ta's Avatar
trust me man your going to love that set up,
Old Nov 4, 2003 | 12:14 PM
chad89ta's Avatar
email me i dont no how to post pictures here but i would like to send you some of my coustom exhaust,it nocked 4 tens of my times
Old Nov 4, 2003 | 12:23 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you can get the holley on a trade id go for it....
i would gofor a Vic Jr intake too... but i think thats only because ive liked it on mine..
ive put torkerII intakes on a couple 305s in the past... they are good street intakes, but they seem kinda small.. esp when you look at your intake size.....
Old Nov 4, 2003 | 12:33 PM
KYL98's Avatar
Car: 1991 Z28
Im going to go ahead and get the Holley 750.....and Im going to browse the intakes one more time....I really like the Victor JR intake...but just want to look a little more. I cant wait to get this thing going.....
Old Nov 4, 2003 | 12:35 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
if you just want a nice single plane intake, there are alot of good vicJr clones out there..
Old Nov 4, 2003 | 05:36 PM
KYL98's Avatar
Car: 1991 Z28
Well got the Holley 750 DP after work today....looks brand new. I got some extra jets and stuff for it....I think there's even a 1.5in spacer for it too. I also went ahead and ordered the RPM air gap intake for now....figured I could try it and if I didnt like it, I could sell it in favor of the Victor Jr. Ill post some pics of my engine/car when all is finished......
Old Nov 4, 2003 | 06:36 PM
PhilM's Avatar
Car: Accepting applications...
Victor Jr with one of these...
Attached Thumbnails Building a 383....need some advice on carb/intake....-dscf0005b.jpg
92firebirdguy
Sep 1, 2016 07:53 AM
Jorlain
Oct 8, 2015 01:57 AM
MSRed91Camaro
Oct 6, 2015 01:56 PM
89 formula TPI
Sep 8, 2015 08:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
