carburetor help?
Car: 1985 Iroc-z
Engine: 355 sbc
Originally posted by 83 Z28 HO
the computer is a pos.
you can put a 58 size jet and gain alot of fuel, or a 54 n kill alot of the fuel feed.
I swapped my jets out for e-check, ran like crap, but swapped em back after emissions
Car: 91 rs,83 monte SS
Engine: rs 305,SS 355
Transmission: rs 700r4,SS th350
Originally posted by hydric
ahhhh isn't that the truth... another thing to keep in mind with a holley is the cfm size can be decreased with the size jets/shoooters (whatever u freaks call them)
Car: '87 Formula
Swap your carb, your going to lose your descent mileage. The only thing the computer has a bad rap for, is timing. It doesnt get that much timing in at the upper RPM's, but you can fix that a whole lot easier and cheaper than buying a new carb. The Qjet will support any amount of power your going to be getting from that 305.
Car: 1985 Iroc-z
Engine: 355 sbc
fnad i'm well aware of that.. I didn't mean to put it in those words, i meant you can downsize the jets to decrease fuel, not cfm (yes i know thats what I said, sorry)
and race cars? I have one on my camaro and i hardly ever take it to the track, daily weekend driver basically... no problems with it cept that it blew a power valve (as older holleys are known to do) but taht was cause my car was running off batteries and didnt have enough juice...
other than that, no rpoblems and i had it for over 2 years with the same carb.. and my brother the person who sold it to me had it for years before that with a another holley carb, so a race car and a daily driver =]
i know holleys arent bad carbs,but to swap from the ccc to a holley(lets not forget a new distributor,and a torque converter lock up kit for the tranny if its an auto),is just a bad idea.there are guys over at montecarloss.com (and im sure here too)running 383's and so on with the factory ccc setup w/simple upgrades ,making big power,while retaining driveability,and economy.when something isnt just right,everybodys first thought is to rip out the computer,and slap a holley on it.
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
Keep the CC quad. If your motor feels weak, the cat is plugged and/or the ignition is weak. The stock carb flows way more then any 305 can use. How old is the O2 sensor? It's what the computer uses to tune the carb A/F ratio.
WhteRbt
Sep 21, 2015 09:48 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
