single O dual carb the bad boy...which?
Old Jan 13, 2004 | 10:01 PM
anubiscougar's Avatar
Ok... tell me, if i where to get a 1000 cfm carb, and put it on an engine, or take two 500's... which would i get better performance out of?
in other words.. near same air flow, dual or single carb, which does better.?
thanks.
Old Jan 14, 2004 | 07:50 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The engine itself does not care how many holes the air came through to get in. As long as the correct amount of fuel is mixed with it, it will be happy.
But, a single carb is a whole lot easier to tune and keep tuned correctly. For that reason alone, I would avoid multiple carbs if at all possible.
Old Jan 14, 2004 | 12:28 PM
k, thanks.
Old Jan 14, 2004 | 09:40 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
dare i/we ask what this is for?
Old Jan 14, 2004 | 10:11 PM
rofl, no. just.. dual or single.
Old Jan 15, 2004 | 04:40 AM
ronterry's Avatar
Car: '94 Corvette
In the old days they did exactly as you stated, with two 500cfm carbs to make 1000cfm worth of flow. The only difference between then and now is they didn't have single 1000cfm carbs, or even 750 for that matter.
You might even see it today put to real use, on engines requiring more cfm then the biggest carb available. 'Carb only' application of course.
I havn't heard of any real performance advantages, with feeding say right & left banks or front & rear with it's own carb...
Ron
Frozer!!!
Jan 19, 2024 04:55 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
beastin91rs
Oct 9, 2015 07:38 AM
Dialed_In
Aug 20, 2015 01:45 PM
