Best manifold for high rpms
hard to find something with that kind of range, a motor with that kind of power range would be, uh, hard to find.
but if you really want to go to 7000 go with a Victor Jr.
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
This intake kicks ***..
-->Click Here<--
-->Click Here<--
In order to not take up more listing space I'll ask this question here. For the factory dual snorkel air cleaner, what are the dimensions of it? Would you be able to fit a 14X3 element in there? Would it be possible to put an X-treme flow on top of it all to allow more flow in? Will the camaro one fit a firebird?
You'll need a truck lid and then you can run K&N #1500. That's the only way to go. But be careful because it does add a little height.
Mine fit under my stock hood with the stock TBI, intake and what-not, but with an aftermarket intake..... it might not.
I got my chrome lid from Jeg's (well actually I got mine from Spohn... but you can get it from Jeg's)
You can put on the K&N top, but it won't do any good with a stock hood. It will be too close to the hood to reep the benefits.
I have a 14X3 extreme assembly on there now, but I would like to make a cold air setup when I put everything else togethor. That's why I was asking about the dual setup. If I use a single plane will it affect my low rpm power by that much?
Car: 1986 Irocz
Axle/Gears: 3.25:1
This is a great flowing intake designed by the late John Lingenfelter sold by Accel. You will need a non-stock hood though.
Car: 1986 Irocz
Axle/Gears: 3.25:1
Originally posted by stupid4901
I don't want anything to do with fuel injection.
dude...thats just a vic or super vic with rails. Not a bad manifold, but it costs several times what the exact same manifold without does.
New rule in this section; No reading a lingenfelter book and then spouting off crap out of it like you actually understood what you read or know what you're talking about.
Car: 1985 IROC-Z / Z-28
Engine: 383 C.I. Stroked 6.3 Litre
Transmission: 700R-4
Axle/Gears: 3:73 Posi
Yeah go with a Victor JR, Add a Demon Carb 750 and up, and you are off to the races! thats what i'm running and i am very happy!
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Lots of combos can go up to 7000 rpms. Just depends on how much you want to spend and how much flow you want on the carbs. My vote would be for a Victor Jr with a Speed Demon carb. Unless you're gonna run a big cam or forced induction then maybe a Mighty Demon (Extra tuning features).
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
