Dual feed line for a Holley 4011
Old Mar 13, 2004 | 07:17 PM
cc2006305's Avatar
Car: 1986 Z28
Transmission: TH700
Does anybody manufacture a dual feed fuel line for a holley 4011?
Old Mar 13, 2004 | 07:22 PM
SOLID LIFTER's Avatar
Car: '87 Mustang LX
Engine: 5.0
Holley still makes them. I bought one for the 4011 on my Buick awhile back from PAW.
Old Mar 13, 2004 | 07:29 PM
Car: '87 Mustang LX
Engine: 5.0
Part # HOL-34-411 in PAW. $19.95.
Old Mar 13, 2004 | 07:50 PM
cc2006305's Avatar
Car: 1986 Z28
Transmission: TH700
Do they also make an electric choke for these things??
Old Mar 13, 2004 | 08:45 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
just a quick question, is the holly doublepumper a 4150 or 4160 series carb? i see all these brackets in catologs and they say "fits 4150, 4160 and 4500 holly series carbs"
Old Mar 14, 2004 | 01:26 AM
Battery's Avatar
Car: 75 & 82 Z-28
Transmission: Saginaw 4 speed
I ordered a bracket for the 4150/4160 for my 750 DP. Fits like a charm. They did mess up though, I was on the phone and telling him my setup, he sent me the 1 that bolts under the entire carb, you need a special throttle cable for this. I think Spectre makes the adjustable throttle cable with no kickdown for holley carbs, like 10$ too
Old Mar 14, 2004 | 03:56 AM
ronterry's Avatar
Car: '94 Corvette
I think Holley discontinued the production of the 4010/11 about tens years ago.
I bought one back in '91 myself. IIRC wasn't it also made of aluminium.
BTW: the 4010/11 is sort of based on the 4150, but dosn't have removable float bowls & metering plates. Insead it's designed more like the Carter AFB, where the whole top comes off.
Ron
Old Mar 15, 2004 | 12:40 AM
AM Racer's Avatar
Both Mr. Gasket and Summit have the line.
It comes with a built in fuel pressure gauge.
Old Mar 15, 2004 | 07:50 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
4150 and 4160 are square-flange carbs, as opposed to the 4155 and 4165 which are spreadbore. 50 is vac sec single pump, 60 is man sec dbl pump. 4500 are the Dominator series.
IMO a 4010/4011 carb isn't a real Holley. They don't produce the power that a real Holley does, and they don't tune the same way. I would recommend getting that emissions / gas mileage / grocery cart replacement thing off of there and getting a real Holley if you have an application that actually demands so much fuel that it "requires" a dual-feed line.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
