TBI to CARB.
Old Mar 15, 2004 | 03:36 PM
MillerTime21's Avatar
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
TBI to CARB.
If im swaping my 305tbi to a 305carbed engine do i have to change my fuel pump? If so what kind do i need and what and where is the best place to get one? THANKS
Old Mar 15, 2004 | 04:17 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
There's a write up about it in the "Tech Articles" on the homepage of a really kool website called WWW.THIRDGEN.ORG
You should check it out.
Old Mar 15, 2004 | 04:40 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You are going to have to check out the tech article. It is not just as easy as some people make it out to be.
Old Mar 17, 2004 | 11:09 PM
SMOKY21's Avatar
Car: 85 s-10 soon
Engine: just a small block
Transmission: th350
Hay dumbass why didnt ya just ask me you helped me do that to my old camaro. Your fuel pump is fine you just need a fpr. Holley has one for like 20 bucks.
Old Mar 17, 2004 | 11:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Don't use an AFPR that regulates by dead-heading the pump. 3-port types with return typically run a lot more than 20 bucks.
Old Mar 18, 2004 | 02:30 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
i didnt find it too difficult to change from tbi to carb. you will need a few new parts though, including carb, manifold, fpr (3 port type like everyone says, mine was $80), and distributor. besides that, i kept my wiring harness hooked up so that my alt and fuel pump worked. you will have to adapt the 2-wire harness to the distributor (so that your new one works). i also have noticed that you need to turn the dist. a bit if you have the in cap type because you wont have enough clearance behind it. but besides that, ive been running a carb for about a year now with little to no problems (any of them being my fault of course ). but give yourself a weekend so you have enough time to work and run to the parts store. and also read the tech article.
Old Mar 21, 2004 | 07:09 AM
dennis6's Avatar
Car: 1991 Camaro RS
You could always get a carb pickup from a wrecking yard and swap your TBI fuel pump out for it. Then get a generic electric carb pump.
Don't forget to deal with the lock up.
Old Mar 21, 2004 | 06:08 PM
CbraKlr88's Avatar
that my good sir, is the best piece of advice one could have given
if you dont deal with it (either with a $200 ish hypertech part or a custom fabbed switch or a neat vaccuum operated no user intervention setup) then youll kick your own *** for wondering where your gas mileage went
Old Mar 24, 2004 | 10:05 AM
mattscamaro's Avatar
what's the name of the hypertech part? i'm doin the same thing
Old Mar 24, 2004 | 11:10 AM
CbraKlr88's Avatar
cant find the hypertech TCC lockup (i think it mighta been posted on here)
but i found this which i think i like better: http://www.northernautoparts.com/Pro...ctModelId=5992
Old Mar 24, 2004 | 11:39 PM
Car: 94 25th TA
Engine: 355LT1
Thanks for the help. By the way how much will it kill my gas milage? THANKS
Old Mar 25, 2004 | 12:38 AM
dennis6's Avatar
Car: 1991 Camaro RS
Rig a lockup setup for your TH700R4 and properly tune your carb. If you have selected a carb suited to your engine (ie no 1050cfm dominator) like a 600cfm Holley DP or VS then you may actually gain mileage.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
RedLeader289
May 28, 2019 01:47 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Gordonr1973
Sep 29, 2015 11:59 AM
