new carb
Old Mar 16, 2004 | 12:34 PM
1fast91rs's Avatar
Car: 1991 RS
Engine: 305 LO3(TBI)
Transmission: TH-700R4
new carb
my friend has a 86 iroc 5.0 qjet and we are going to be replacing the qjet and intake with a edelbrock 650 carb(edl-1806) and a edelbrock performer intake(edl-2101) from summit racing and i was wondering are we going to run into any problems with this setup and are there any special things we need to do? i was wondering also how many plugs do we need for the intake and was size are they?
Old Mar 16, 2004 | 12:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Is there something in particular wrong with the stock carb?
If not, you're going through a lot of trouble and expense for no improvement in performance.
You'll need a non-CC distributor, unless this is a Canadian car. You'll need brackets to mount the throttle cable(s). If automatic tranny, you'll need some means to lock up the torque converter clutch since the ECM will now be brain dead.
Fix what's really holding the car back - air cleaner (need dual snorkel), exhaust, cam.
Old Mar 16, 2004 | 01:07 PM
1fast91rs's Avatar
Car: 1991 RS
ive read a couple other post on here and they have said you can get by with a cc hei
https://www.thirdgen.org/techbb2/sho...hreadid=226620
https://www.thirdgen.org/techbb2/sho...hreadid=217860
Old Mar 16, 2004 | 01:12 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
LIke five7 asked. Is there anything wrong with the carb that is on there now? if youre looking for performance gains, bigger gains can be had elsewhere...that is assuming the car is bone stock....perhaps you might see something if this car already has headers and a good exhaust. If not, what good is breathing in, if it cant breath out.
Old Mar 16, 2004 | 02:05 PM
1fast91rs's Avatar
Car: 1991 RS
the carb is shot is is leaking fuel out of the gaskets and it is very moist.the car has a 3in exhaust and headers.we want to put a cam in it but we are not sure how big to go on a 305
Old Mar 16, 2004 | 05:27 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
Change the carb if you want to change the carb. You won't be dissapointed.
550- 600 cfm will do.
Old Mar 16, 2004 | 05:30 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
if you HAVE to change the carb, cuz gaskets are fairly inexpensive and "easy" to replace, i would change your cam at this time. why fork over the dough for a carb that isnt really going to do much for a stock 305? if you dont do anything else to the motor and still want to change the carb i would look at a 600cfm instead of a 650 but thats just me.
Old Mar 17, 2004 | 01:11 PM
1fast91rs's Avatar
Car: 1991 RS
what would be a good cam to go with?
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
