Gas selection...
Old Apr 19, 2004 | 07:13 PM
Camaroguy18's Avatar
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
Gas selection...
Ok I am aware of racing fuel, along with other "enhancing" additives, however my question is about the best gas to use for a daily driver (if there is a difference). Basing it on my car, with a 305 and a carb, is it better to put say 93 octane in, instead of 87?, is it worse?....does it even make a difference. All I really know is that the higher the octane, the more clean it burns, and the higher the price...however Ive been putting 93 in my car virtually since I've had it. Any suggestions?
Old Apr 19, 2004 | 07:48 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Run the lowest grade you can without audible knocking. Premium gasolines used to contain more detergents than regular, but it's all pretty much the same now.
Old Apr 19, 2004 | 08:20 PM
AM Racer's Avatar
If your engine doesn't require it, then using it has no real benefit.
Higher octane is just an anti knock index number. For pump fuels, as the octane goes up, the btu output per pound goes down..
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
86maro_252
Oct 10, 2015 06:52 PM
kx3g
Sep 28, 2015 08:14 AM
reactor60
Sep 22, 2015 01:44 PM
