quick vacuum hose routing ?
Old May 10, 2004 | 01:38 AM
ramrod85's Avatar
Car: 85 Z28
Engine: 350/ 290hp EZ-EFI
Axle/Gears: 3.08 posi
I have an 85 LG4 setup and hope someone can tell me where the vacuum line from the back of the egr control solenoid goes. The two lines on the front go to the egr valve and to intake vacumn on carb.
Old May 10, 2004 | 05:30 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's all that goes to it. The 3rd "fitting" is a vent, doesn't get a hose.
Old May 10, 2004 | 09:53 AM
ramrod85's Avatar
Car: 85 Z28
Thanks RB. Is there suppoxe to be a small filter there? Sure looks like something should go on it though, there is a metal keeperon it. Weren't you in Memphis at one time?
Old May 10, 2004 | 09:58 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes there is.
Yes I was. I've been a couple of other places since then.
Old May 10, 2004 | 03:56 PM
ramrod85's Avatar
Car: 85 Z28
Thanks. I went ahead and got a new one. The little keeper on the back holds a small filter screen.
Old May 11, 2004 | 08:58 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
I don't have a little filter on mine either. Does that vent expell pressure, or does it release vacuum? I guess my question is how important is the filter? ... and if it is, where do I get one?
thanks for your time,
phil
Old May 11, 2004 | 10:52 AM
ramrod85's Avatar
Car: 85 Z28
Damn Phil, you're almost as old as I am. I dont think the little filter on the control silonoid is very important. GM couldn't have done it any cheaper. Here's picture of the new one.
Old May 11, 2004 | 11:20 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I know this is going to sound stupid, but....
The filter expels vacuum.
Imagine what would happen if there were not some kind of a vent on that line going to the diaphragm.... the solenoid valve would open, send some vacuum to the diaphragm, which would do its thing; when the time came, the solenoid valve would close, but if there was a perfect seal, the diaphragm would remain operated.
So all that the vent does, is let the vacuum escape when the solenoid drops out. The filter is there to keep out the dirt that would come in with the replacement air.
You gotta be careful that too much doesn't escape though, since that could be quite dangerous. It's been conclusively proven that laboratory rats can survive for a few seconds at most in a vacuum-enhanced environment. Iamgine a whole city with too much vacuum in its air. And that stuff is nasty if it leaks too; it gets all over everything, and the only way to clean it up is with a special tool called a vacuum cleaner. Very messy.
Old May 12, 2004 | 12:18 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
wtf RB?
Old May 12, 2004 | 03:34 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
hahaha.....all that "vacuum air" will really screw up your lungs....luckily i can sell you normal air for a cheap price
Hotrodboba400
Dec 10, 2019 07:07 PM
sailtexas186548
Feb 17, 2017 03:07 PM
85 Jimmy
Sep 30, 2015 07:56 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
