Changing Jets and rods??
Old Jun 9, 2004 | 07:58 PM
black85camaro's Avatar
Car: 85 Camaro
Engine: 350 Carbed
Transmission: Stock 700r4
When changing the jets in a Performer 600 cfm carb do you have to change rods too?
Car wont take full throttle. Its bogs and dies. New tune up, rejetted to 2 sizes larger then stock. Fresh rebuild. and high flow neddle and seats.
-Terry-
Old Jun 12, 2004 | 02:17 PM
Damon's Avatar
No, on an Edelbrock Performer you can change the jets independently of the rods. Jets will make the whole calibration richer/leaner across the board from just off idle all the way to WOT. Rod changes can have different effects depending on what rods you select.
You may want to have a look at another post in this forum titled "can someone help me get my A/F ratio dialed in?" or something like that. More info you may want to know about in there, too.
BTW- it is rare for a new Eddy carb to simply have a big lay-down right outta the box. At least one that continues for more than just a fraction of a second. If your carb is experiencing a quick bog and then it hauls butt, accelerator pump tuning issues are much more likely than basic jetting/calibration problems. Eddys are reaonably close outta the box as far as jets/rods go. Accelerator pump issues are much more common.
Old Jun 15, 2004 | 09:56 PM
Car: 85 Camaro
Engine: 350 Carbed
I rejetted it to about a 800 cfm is why I asked. I didnt have this trouble until then and someone told me to change rods since I changed the jets.
Update: The carb seems to be doing great. Rebuilt it and cleaned all the ports. High flow needle and seats, and tuned up the ign. system.
Thanks for the reply!
-Terry-
Old Jun 16, 2004 | 12:02 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
-Terry-
Hmm... I don't think changing the jets will change the air flow capacity of the carb.
Old Jun 19, 2004 | 04:31 PM
kd5boc's Avatar
Car: 92 RS
I was about to say the same...see here for adjusting that carb....
Main page
http://www.edelbrock.com/automotive/eps_intro.html
Adjustment
http://www.edelbrock.com/automotive/eps_sect2.html
also need to know if it's the 1405? or 1406?
1405 chart
http://www.edelbrock.com/automotive/eps_1405.html
1406 chart
http://www.edelbrock.com/automotive/eps_1406.html
easy enough to mess with...
easy enough for the street.
Out-Cast
Mar 22, 2019 09:39 PM
fasteddi
Sep 2, 2015 10:29 AM
mantaguy
Sep 1, 2015 08:39 PM
gixxer92
Sep 1, 2015 04:32 PM
Thaney9
Aug 29, 2015 03:16 PM
