500cfm too small for a 305?
Subscribe
Jun 17, 2004 | 07:24 PM
I got an edelbrock 500cfm carb on my 305 HO w/ a one inch carb spacer to cut down the heat going to the carb. Is this too small or just right?
Reply 0
Jun 17, 2004 | 07:37 PM
Re: 500cfm too small for a 305?
Quote:
many variables
500cfm through a dual plan, single plane
square bore and spread bore I think make a difference
what mods are done to the car
stuff like that
inmho I would use a 500 for a mostly stock car though
but then again been a while since I did anything with carbs
Reply 0
Jun 17, 2004 | 07:46 PM
Dual plane edelbrock intake, flat top HO pistons, crane xtreme energy cam. thats the main mods .. the engine was just rebuilt.
Reply 0
Jun 17, 2004 | 09:12 PM
(Comp Cams makes the Xtreme Energy series cams )
Which cam was it?
Reply 0
Jun 17, 2004 | 09:53 PM
Doh, i get them confused constantly
Lift: .490''/.490''
Duration: 274°/286°
RPM Range: 1800-6000
Reply 0
Jun 17, 2004 | 10:01 PM
way too small a carb for that cam. That is a big cam for a 350. let alone a 305.
i take it that this isn't your daily driver?
with a dual plane intake you can get away with a bigger carb.
i would say go with a 650cfm or so, and ditch the edelbrock.
Reply 0
Jun 18, 2004 | 03:07 PM
I wouldnt ditch the edelbrock, but I would definately look at a bigger one.
Reply 0
Jun 18, 2004 | 05:14 PM
Actually, it is my daily driver .. and its a damn expensive one at that. Can i tune this carb to work pretty good with my motor? I cant afford a new carb yet
Reply 0
Jun 18, 2004 | 06:40 PM
yeah, you can jet it bigger, it will run just fine as a daily driver.
a bigger carb will just perform better.
why such a big cam on a 305 that is a daily driver?
Reply 0
Jun 18, 2004 | 10:36 PM
My friend is giving me an old holley 600cfm. Ill pop that badboy on there , i like edelbrock more but cant beat free. The cam was out of a 350 running deep in the 10s , i got a great deal on it from another friend. Its alotta lift but not a lot of duration so it likes to rev, and waste my fuel at idle.
Reply 0
Jun 18, 2004 | 11:47 PM
the 600 will probably run harder assuming it is in good running order, or if you rebuild it.
the 500 will run fine it is just a restriction a WOT. you might even see some vacuum at WOT with that carb. the 600 should help that.
Reply 0
Subscribe
