carb gasket
carb gasket
i have a carb spacer on my car it came with a very thin gasket i want to rebuild my carb but can't find one of these gaskets is it ok to use the engine seal gasket material and make my own thanks in advance
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There are vacuum passages in the base of the carb that will get plugged if you use gasket maker. Any parts store should be have the gasket. Try a Mr. Gasket 56 or 56A.
the local parts stores don't have it i don't want to use the silicone gasket stuff what i am talking about is the stuff that comes in a roll you but the old gasket on it trace and cut out will this stuff work
