mechanical secondaries w/ auto?
Old Sep 19, 2004 | 10:16 PM
pskel350's Avatar
i know its not a good idea....but why?
can it be made to work?
i just converted my car back to a pro-built auto trans, and now its doesnt want to run worth a crap, when its supposed to downshift the engine backfires and wants to stall. i have a 6210 carb, that is modified, probably more of a drag carb now, but i've never had a problem with it fouling plugs at all.
anything i can do to make the car run better
Old Sep 19, 2004 | 10:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
When the RPMs drop during a shift at WOT, flow through the secondaries drops considerably and makes the car go lean until secondary airflow picks up again. If your converter stalls high enough this might not be such a big problem.
Old Sep 20, 2004 | 05:16 PM
65panhed's Avatar
Car: 1984 Z28
Engine: L69 305 HO
Transmission: 5 speed manual
Axle/Gears: Auburn pro yukon 3.73 gears and axl
What mods were done to make a 6210 drag only?
Old Sep 20, 2004 | 07:54 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I don't see why it would be a bad thing.
Old Sep 21, 2004 | 06:05 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Works fine, as long as the driver doesn't stomp it to the floor.
What it does shifting isn't near as much of an issue, as what it does off the line.
I've run 6210s on auto cars for years; in fact, I've even used one sometimes on my Land Yacht (74 Caprice convertible 454). Not a problem, as long as the driver knows how to drive it.
Sounds to me like in your case, the secondaries aren't feeding any fuel, or at least, not enough. Check their fuel level.
Old Sep 22, 2004 | 11:48 AM
pskel350's Avatar
the car is having serious problems yet.....
the car goes extremly lean at anything more then 1/3 throttle. but yet it idles just on the rich side. also for some reason the engine is only making 4" of vacuum, when i used to have 14. could this be my whole problem?
i havnt checked the fuel level for the secondaries yet, but now that i could drive the car for a few more minutes, the car goes way lean before the secondaries even open. could i be right when im thinking that the distributor isnt getting enough vacuum to advance the timing?
im about ready to park the car until the new engine with FI is done this winter
Old Sep 22, 2004 | 11:55 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes.
Old Sep 22, 2004 | 12:03 PM
pskel350's Avatar
Originally posted by five7kid
Yes.
lol
so how do i fix it
Old Sep 22, 2004 | 01:58 PM
Air_Adam's Avatar
lol
so how do i fix it
Find the leak
Old Sep 22, 2004 | 04:45 PM
pskel350's Avatar
i dont think that it is a leak, normally with a leak the car runs rough and/or stalls. the car will set and idle all day long though, and just doesnt have any power, doesnt miss or anything.
Old Sep 22, 2004 | 08:10 PM
65panhed's Avatar
Car: 1984 Z28
Engine: L69 305 HO
I guess the question was not of sufficient worth to be answered..........
Old Sep 22, 2004 | 09:56 PM
pskel350's Avatar
just trying to keep on the problem at hand
basically some things were removed, and a lot of other stuff was modified....unfortunatly im not excactly sure since i didnt do it
Old Sep 22, 2004 | 11:51 PM
louich's Avatar
Car: 75 firebird..9.30@150.5
Engine: twin turbo pump gas sbc
Transmission: glide
Axle/Gears: 3.42s
sounds like they romoved and modified the wrong things
Old Sep 23, 2004 | 09:23 AM
five7kid's Avatar
Go over the list of things that have been done between the time it ran okay and when it started misbehaving.
Only thing I can figure out from what you said is you put in an automatic transmission. That of itself would not lower vacuum to 4". Something else must have happened.
Old Sep 24, 2004 | 04:51 PM
inohcent's Avatar
my 6210 has only given me a problem once and that was due to low fuel pressure. Like rb said. If you just stomp the hell out of the pedal you wont get the same reaction as a steady press down.
rubblerubble
Mar 13, 2016 06:57 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
gta90
Sep 15, 2015 04:00 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
FlynIroc
Sep 28, 2001 05:45 PM
