98 4th gen 6 to pre 93 8
Well as stated in the topic i got a 98 6 with a 5sp, i just got the ok to sell my car since ill be 18 soon and wanted to get a third gen v8. First off i have considered getting a vert but to my dismay they only come in 305's. i have thought of the change over to a 350 and carb. My cars worth about 5k and ive got 1k saved so about 5.5k to work with including purchasing the car. I am almost witouth a doubt going carb due to my severe hate for computers and love the flexibility i can get from a carb. so i am up to any suggestions, my goal would be gettin a 350-400 hp daily driver and i dont care too much about the milage as long as freeway is about 15. o and if at all possible id like to get a t-56 in there, but that would be a bonus, otherwise a 700-r4
Transmission: 4L80E/4L80E
3rd gen 350's only came with automatics. If it came with a manual tranny, it had a 305 or smaller.
All 3rd gens sold in the USA had computer control induction/ignition.
Computer control is the best way to get performance with economy. The flexibility afforded by programmable EFI trumps non-feedback carbs by a long shot. Performance parts are a lot less expensive for carbs than for EFI, but you pay that back with reduced economy.
i kno it gets worse milage but, from what ive read and researched, its much easier to modify a carb rather than a computerized engine, personally after my v6 im very sick of them and would much rather have a carbed motor.
i have considered a 383 shortblock and puttin it in under the stock heads and intake off of say a 350 post 86. then converting to carb, would i not achieve more power through the carb rahter than the computerized one, leaving the milage out?
For the same money, yes.
What, if any, emissions inspection/testing do you have to go through? That's really the most important factor for a street-driven car.
currently i live in houston texas, where ill get my inspection taken care of while i have TPI on the car so it will pass for the duration that i will be living there, in 6 short months i plan on moving to florida to attend UF and there arent ANY emmissions so i wont have to worry about it at all.
I think ive pretty much made up my mind. I belive im going to go with the 383 carb swap, not sure what the host is gonna be but most likely it will be TPI.
i hoping to achive around 400 hp
any thoughts on this would be appreicated. so far ive listed that i will need
1. carb
2. intake mani
3. HEI dis
4.3 port regulator (could someone explain this)
5. 383 short block
this is all i can think of at the moment im pretty sure ill need new heads if im not mistaken but im clueless as what to be lookin for with a 383, plz if you have any exp lay it on me
thanks!
1. carb
2. intake mani
3. HEI dis
5. 383 short block
thanks!
with a switch to carb and 383 short block with the stock heads what do yall think id have at the wheels, 700-r4.
i do plan on upgrading the heads but i figure the short block would add more power to begin with but im not sure. ill b starting with a 305 vert first tho
