Going DFI to carb w/ supercharger, Questions
Old Jan 22, 2005 | 12:42 PM
Project's Avatar
Car: 85 Camaro Z28
Transmission: 700-R4
I have fooled with this GEN VI DFI, and haven't seen any pros to fuel injection...nothing but a pain in the *** expensive and no power increases that i thought were worthwhile.
Question is, going from DFI w/ supercharger to carb w/ supercharger, what is needed exactly? I have found $500 blower carbs, and I'm not sure what exactly I need for a carbed s/c application? Anything I should be worried about detonation?
Please help? I'd like to run a race demon or a might demon if at all possible.
Old Jan 22, 2005 | 08:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you haven't already, you're probably better off asking over on the Power Adder forum.
About all I know about the topic is what I've read in magazines. Don't even spend time over on that forum on this Board. It just isn't where I'm going.
Sorry.
Old Feb 6, 2005 | 06:06 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Re: Going DFI to carb w/ supercharger, Questions
You need a blow through carburetor or you can get a regular douple pumper modified to work.You would also need a bonnet and ducting for the carb.
Old Feb 7, 2005 | 03:11 AM
contactpatch's Avatar
Engine: sbc 350
Issues for a blow-thru carb are:
Fuel floats can collapse,
Fuel pressure must be referenced to boost,
fuel bowl vents must be on the 'inside' of the carb hat,
throttle shafts can leak,
don't forget the ignition,
how are you retarding the spark, under boost?
Old Feb 15, 2005 | 05:47 AM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
go here for what you need to do with the carb....
http://www.hangar18fabrication.com/blowthru.html
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
e3pres
Sep 9, 2015 01:51 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
