Sputtering when i shut car off??
Old Apr 11, 2005 | 12:44 PM
shaun777's Avatar
Car: 1987 Firebird formula
Engine: 350 5.7L
I think this problem might have sumthing to do with my carb setting ( i have an edlebrock performer intake with an edlebrock 4brl 750cfm??) i think its a 750 anyways the guy i bought my car from was a total airhead and had little if any respect for the car)i have a feeling its putting to much fuel in and isn't cutting the fuel off immediatly once the ignition is shut, off but jus thought i'd see what everyone on here thinks because they saved me alot of time and money last time i needed help........this has just happened lately, here's the problem.....when i turn off the ignition on the car after any type of driving it, it seems to sputters a few times before the engine completly dies, i'm kind of worried about this but i'm not completely sure why its happening so if anyone can give me there opinion on this would help alot, if you need any other info let me know and i'll see what i can do, thnks
Old Apr 11, 2005 | 03:17 PM
BT283's Avatar
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
Your problem is probably in the timing. I seems like your timing is to high or you run cheap gas. Try turning the timing down a couple of degrees and see what happens.
Old Apr 11, 2005 | 07:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'd guess too much timing and/or idle speed screw too far open.
Old Apr 11, 2005 | 11:39 PM
blue_tacos's Avatar
Car: 82 Berlinetta 87 Iroc
Engine: 327
Idle is probably to high
Old Apr 13, 2005 | 09:12 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Idle speed to high
Too much timing
Bad fuel or not enough octane
Too hot of a spark plug
Reddeath210
Oct 6, 2015 08:20 AM
kyleb24
Aug 15, 2015 08:24 AM
djmarch
Aug 9, 2015 05:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
