Carb Trouble
Car: 1982 Pontiac Trans Am
Engine: SBC 355
Carb Trouble
Carb guys, I need some serious help. I have a 350 small block in my 82 TA. I have a Holley 600 cfm carb and an HEI Accel distributor/coil. We fired up the car for the first time last night and adjusted the carb and timing to 0 btdc just to get things working. We were able to drive the car and things seemed fine. We took it home and shut it off.
Now today, the car will not start and just backfires. We tried adjusting the distributor but it did not help. All I got was a ton of backfire. What could have possibly changed after simply shutting the car off? Does this seem like a timing issue or a carb issue? Anyone have any ideas?? Please?
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
that's a timing issue. no idea what it could be, make sure all your connections are good. all plug wires, ect.
Engine: SBC 355
I kinda figured....but nothing has changed since last night. My float levels seemed to be fine and we set the idle close on the carb. Would the electric choke have anything to do with it?
Car: '82 Camaro
Engine: 383
Transmission: TH-350
sreZ28
Oct 22, 2015 08:21 AM
