Anyone ever used NOS with a cc Q-Jet?
Car: 1984 T/A
Engine: L69
NOS is a snap with EFI, but I was thumbing through my Summit catalog and found a few NOS kits thats availible for the q-jet's. They have one thats set to 125HP and one thats adjustable to 100-150HP. My questions are these kits setup to be used with a stock q-jet, my guess would be no, and what modificatins are needed to run NOS?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Apart from perhaps taking a couple of degrees of timing out, I can't think what else you'd want to do to use nitrous.
Car: 1983 G20 Chevy
Transmission: 4L60
Would work just like a standard carb since almost every computer vehicle I can think of goes into open loop at WOT.
IIRC the LG4 and L69 both use a knock sensor so retarding the timing more than 2* may not be necessary.
Car: 1984 T/A
Engine: L69
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
LG4s did not get a knock sensor until I think 1985. 82's and 83's did not get them i know.
Transmission: 4L80E/4L80E
That's my understanding, knock sensor for LG4 in '85 when the compression was raised.
What I wasn't clear about was whether the knock sensor is active in open loop.
Car: 1983 G20 Chevy
Transmission: 4L60
My 1983 had one but maybe the cars didn't get one. I know the trucks with the CCC carb had them.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
My 1984 LG4 doesn't have one, but my 1985 LG4 did.
It makes no difference when it comes to nitrous (having a knock sensor), because typically nitrous melts pistons, not hammering them with detonation. Either that or you throw rods out the block.
Do buy an adjustable nitrous kit for any car - its more adaptable. Do upgrade your fuel system - a stock block pump is not going to be able to keep up with a 125hp nitrous kit, so either go electric (near the tank), or get a high volume block pump and regulate it.
Rule of thumb for timing is 2 degrees for every 50hp of nitrous. Since stock LG4 timing is so low (ECM does this on purpose), you probably only want to retard it 2 or 3 degrees with a 125hp kit.
Engine: 383 Carb
Transmission: 4L60
Car: 1984 T/A
Engine: L69
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
I know this post is almost a week old, but I had to reply.
Back in 1990 I bought a mint 1984 Caprice 2 door that had the LG-4. I installed dual exhaust, a shift kit, posi, and then topped it off with a "Super Power Shot" from N.O.S. They still make this kit. It worked very well on the basically stock LG-4.
Just make sure your fuel pump puts out at least 6 psi @ 60 - 80 gpm.
It comes with jets for 75, 100, 125 hp, and you can order the jets for 150, and 175 hp. I threw the 125s in it and never looked back.
Later on, I traded it and the edelbrock fuel pump I bought, for a case of beer.
I quit drinking since then.
Hotrodboba400
Dec 10, 2019 07:07 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
