Throttle and TV Cable Bracket for Demon
Old May 11, 2005 | 04:01 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
I have replace my Holley 3310 with a Speed Demon 750 and the base plate for the Demon do not have the hole that maintains the bracket in place. What bracket can I use for Throttle and TV Cable for Demon Carb.
This is my orginal bracket HLY 20-95:
Old Mar 20, 2008 | 06:13 AM
pezza's Avatar
Re: Throttle and TV Cable Bracket for Demon
I know this is an ancient post but have done the same transition and wondered what brackets ppl are using if they have speed demon carbs?
Derek
EDIT: Oh just found this... https://www.thirdgen.org/forums/atta...tlebracket.jpg
Old Mar 20, 2008 | 11:13 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Hmmm, that one seems to have fallen through the cracks.
But, since it's been brought up again, that's a minor part of the swap. The much more important part is the geometry corrector bracket for the cable attachment to the throttle arm.
Old Mar 20, 2008 | 11:25 AM
pezza's Avatar
Yes I have been reading up about it. Will have to have a another look once I replace the *customised* holley bracket that I am still using.
The bracket does move around a bit and I tend to notice when the car shifts harder and higher up the rev range with this 700R4. ALso kickdown is very hit and miss. Having read the warnings about causing damage, I wont drive until I get the replacement part.
Old Mar 20, 2008 | 12:13 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
I am using that CSR bracket that you pictured. The throttle cable and kickdown cable both work fine, but I dont know where to correctly put the return spring. Any advice?
Thanks,
Dennis
Old Mar 26, 2008 | 04:20 AM
pezza's Avatar
Not sure about mounting the return spring but I will have one of these soon and will let you know what I find!
Old Mar 26, 2008 | 04:46 AM
ekoller's Avatar
I have the CSR bracket and I just put a bolt through the AC bracket and drilled a hole in the end to mount the spring to.
Old Apr 10, 2008 | 10:08 AM
pezza's Avatar
Hi Denis,
CSR state that their brackets have means to use a the return spring. The only place I could see where this could be is in the top left hand corner maybe.
Check the little notch in the top left in the following pic?
http://flickr.com/photos/7457194@N03...n/photostream/
Old Apr 10, 2008 | 10:30 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Like said before there is a small notch in the back of the bracket for a return spring. You will need to get a narrow return spring as a wider one will rub on the bracket.
TheTraut88
Sep 11, 2015 05:16 AM
GouldyGTR
Sep 7, 2015 09:05 PM
TheTraut88
Sep 7, 2015 05:22 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
