carb id help
Old May 23, 2005 | 07:38 AM
doug86z's Avatar
Car: 86 z28,
Engine: 1978 350 bored 0.30 over
carb id help
I was just wondering if anyone out ther could give me some help. I have just aquired a couple of 4 barrell carbs and can't find out any info about them. The numbers are as follows.
Carb #1- Holley, list #6339, other #s D2HF-9510-DA
Carb #2- Carter WCFB, # on tag- 2197S The carter one is different looking.
I wanted to know if these are desirable carb or not as they both look to be in very good condition, as a matter of fact, the Carter one looks like it has never been used before.
Any help that you can offer would be very appreciated.
Old May 23, 2005 | 08:29 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The Holley is an OEM carb for a F*rd application, 72 model. I'm betting it's for a truck.... probably a 360 motor but I don't know that for sure.
No clue about the Carter.
The Holley might be desirable for use on a F*rd, where its linkage will hook up and work. It won't be a particularly "good runner" though. It's probably about a 550-600 CFM unit. I can't recall what the common flow "rating" was on those small factory carbs; 585 maybe?
Old May 23, 2005 | 01:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Wow, a Carter WCFB? That was the original 4 bbl carb from the 50s, mostly famous for weighing something like 25 lbs. I think they were mostly used on Chryslers, but I'd have to double check. It was largely obsoleted when the AFB came out a few years later. It's value as a performance carb is pretty much nil, but you might be able to get something for it from someone doing a restoration.
Old May 23, 2005 | 01:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If it is a WCFB, also used on 220 HP Super Turbo Fire, aka "power pack", and on dual quad 283s in 1957.
Everything else said pretty much sums it up.
Old May 23, 2005 | 04:54 PM
doug86z's Avatar
Car: 86 z28,
The wcfb looks like it has never been used before. It's actually a lot lighter than the holley carb. I'm probably going to sell it though as I don't have any use for it.
Old May 23, 2005 | 05:06 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Lighter than the Holley? That's pretty unusual, WCFBs have a cast iron base.
According to my list, that carb was OE on a 1955 Buick Super M-50, Century 60 or Roadmaster 70.
Old May 23, 2005 | 06:20 PM
doug86z's Avatar
Car: 86 z28,
I know they did but this one is aluminum, don't know why but like I said it doesn't look like it has ever been used, maybe it was rebuilt and upgraded. By the way I got both of them for free.
Old May 23, 2005 | 06:24 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The last WCFB I rebuilt, was off of a 56 Buick Roadmaster. That was probably 20-25 years ago. Haven't even seen one since.
It was heavy as hell.
It was a piece of dung. Imagine stomping your pedal to the floor, and having your mixture vary as you go over a bump.
Kind of like the Edelbrock Carter carbs.
It would be BEYOND PRICE to somebody with a 55 Buick, and a carb destroyed by moisture or whatever. Put it on ebay, and be prepared to wait. Obviously there won't be people by the thousands clamoring for it; but when the right one shows up, he/she will WANT THAT CARB BAD. Seems like I charged the guy that I rebuilt that one for, about 45 or 5 times what I usually charged. After all, I had to do extra work; took about 3 or 4 phone calls to run down the kit. What a PITA.
I think Ape has the same list I do http://www.thecarburetorshop.com/Kbuick2.htm
Old May 23, 2005 | 06:52 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Are you sure it's complete, not just a replacement main body or something? The base of a WCFB is cast iron and the body is actually zinc, not aluminum. Only the top plate is aluminum. They weigh 18 lbs, no joke.
Old May 24, 2005 | 07:30 AM
doug86z's Avatar
Car: 86 z28,
It's a complete carb and it only weighs in at about 10 lbs. I will try and get a pic of it online later.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
