Jet Change Tool
Old May 20, 2005 | 07:51 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Jet Change Tool
Changing jets on a 650 Demon.
I can do the primaries easy enough with a flat blade screwdriver but the secondaries are a pig to get at because the distributor is in the way.
I used a flat blade 3/8 socket without the drive and turned it with a small adjustable wrench. This worked but it's a halfassed way to do it could easily break the jet.
The Holley jet change tool is just a screwdriver and would'nt fit unless it could be bent 90*
Any suggestions on this.
Old May 20, 2005 | 08:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Take off the metering block and hold it in your hand.
Old May 20, 2005 | 08:20 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
I'd just as soon leave it on there - one less step. Easiest solution would be if the jet tool rotated 90* or if there is some similar sort of tool available.
Something like this stromberg tool only smaller.
Old May 20, 2005 | 09:44 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TH-350
Try using Max Jets (check Jegs). They use a standard 6 point wrench/socket to remove instead of the flat heads. That'd be the easiest solution I think.
HTH
Old May 20, 2005 | 10:17 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
HTH
Thanks for the response. I just bought a box of Holley jets so it looks like I'm stuck with them..lol
I'm surprised that Holley doesn't make a wrench for this. Mostly I run the car at Mosport which is a fairly fast road course similar to Watkins Glen where you can end up dead in less time than it takes to say "take off the metering block and hold it in your hand" so I like to check the car over in the half hour or so between run groups and I would rather not spend any more time than necessary with things like changing jets. I guess I may have to just fab something up for this.
Old May 22, 2005 | 07:59 PM
thebigwelsh's Avatar
Car: 88 firebird under construction
Engine: 350 with trick flow everything
Transmission: th350
Cant you just pop the whole carb off. I know i can have mine off in like 2 mins. *shrugs*
Old May 24, 2005 | 06:55 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
it takes less than half a second(literally) to pull the block out after bowl.Just make sure you have re-usable gaskets.
Old May 24, 2005 | 05:20 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
Thanks, I didn't realize that the block came off that easily. Gaskets for the bowl sort of tore a bit when I took them off but were OK so that's why I didn't feel like taking it apart any further. I got some new gaskets for the bowls and blocks.
colton_carlson
Mar 8, 2019 12:21 PM
Dkelz313
Apr 7, 2016 10:38 PM
fasteddi
Sep 2, 2015 10:29 AM
TheExaminer
Aug 25, 2015 07:34 PM
383backinblack
Aug 15, 2015 06:36 PM
