weird edelbrock problem
Old Jul 14, 2005 | 12:28 AM
gtaeric's Avatar
Car: '88
Engine: 305tpi
Transmission: t-5
So I just finished getting evrything all put together and its time to start my motor. I have a brand new edelbrock 600 w/ manual choke. I can get the engine to start, but its really rich, and it will only idle about 5 seconds before the secondaries open up and flood the engine out completely!! And then for the next 10 seconds or so after its off, gas pours out of the top of the carb and just pools up inside the throttle blade area. I am using a Carter electric fuel pump @ 6psi, and I checked to make sure that is was in fact at 6psi.
On a side note, when I first got the engine together, I had the distributer in backwards and accidentally started a small fire on the top of the carb , but I put it out pretty quick. Could this be related?
Old Jul 14, 2005 | 12:32 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Take the top off, clean the needles and seats and set the float levels.
Old Jul 15, 2005 | 07:51 PM
gtaeric's Avatar
Car: '88
Engine: 305tpi
Transmission: t-5
Alright, I pulled off the top of the carb, checked and cleaned the needle and seat assemblies, checked the metering rod assemblies and lowered the float level, but nothing changed. It seems like the fuel bowls are just overflowing badly, but the fuel pump is putting out exactly 6psi, I checked. Any other things I could check?
Old Jul 16, 2005 | 05:56 AM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
had the same problem with my holley. i had some very old brass floats in it and they had a leak. so they are soaked with fuel and resting on the bottom of the fuel bowl.
replaced them with nitrophyl floats and everything is fine
nebu.
Old Jul 16, 2005 | 10:45 AM
contact's Avatar
Engine: sbc 350
this is hard to believe.
try this test,
from a gas can 9 or so feet higher than the carb,
run gas to the carb by gravity.
is the carb flooded and leaking gas?,
or are the needles holding back the flow?
Old Jul 16, 2005 | 06:14 PM
gtaeric's Avatar
Car: '88
Engine: 305tpi
Transmission: t-5
Thats a good idea. I'll try it and let you know. Thanks for the ideas guys.
Old Jul 17, 2005 | 06:21 PM
gtaeric's Avatar
Car: '88
Engine: 305tpi
Transmission: t-5
nebu.
Are there nitrophyl floats for edelbrock carbs too?
Old Jul 18, 2005 | 11:43 AM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
only found these.
nebu.
Old Jul 18, 2005 | 07:05 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Supposedly they exist, but I've never seen them. I'd ask some of the blower shops.
Take the top of the carb off, remove the floats and shake them. If you can hear gas sloshing around inside, then they're leaking. If that was the case, considering that you have a brand new carb, I'd be trying to get warranty replacement before I'd be looking for hard-to-find third-party replacement floats.
Old Jul 18, 2005 | 07:21 PM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
if they are leaking, maybe a cheaper solution is to solder the brass ones. just make sure they are free of gas did that to mine till i got nitrophyl floats.
nebu.
Old Jul 19, 2005 | 06:20 PM
gtaeric's Avatar
Car: '88
Engine: 305tpi
Transmission: t-5
I took them out and shook them, and they were empty. The only other thing I can think of is maybe because I mounted my electric fuel pump off to the side in the engine bay instead of by the fuel tank. I just couldn't find ony good space back there, and all the fuel lines were so rusty I didn't want to mess with them. I know that its at exactly 6psi, but would it matter with it almost being a puller pump instead of pushing?
Old Jul 19, 2005 | 06:27 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
it definitely has to do with the needles and seat area of the carb... either they are weak and need replaced, adjusted, or they are being fed to much preassure
Ghettobird52
Jul 5, 2024 11:18 PM
Cleotiz
Jan 6, 2018 08:56 PM
CORV3TT3
Aug 23, 2015 11:26 AM
86IROC112
Aug 17, 2015 02:00 PM
sreZ28
Aug 14, 2015 07:48 PM
