Making cc q-jet wiring/vaccum look acceptable!!!
Old Aug 7, 2005 | 11:35 PM
theboilermaker's Avatar
Car: 87 camaro sc
Engine: 357 w/ cc qjet
Transmission: 700 r4
Hi there.
I have an 87 camaro with the original GM cc q-jet. I am swapping the 305 to a 350 but i have been persuaded into leaving the cc q-jet for now. I cannot stand the mess of wires, one ways valves, and vaccum lines strewn across the engine compartment in the stock set up. I would like to rerun the wiring away from my valve covers and intake manifold as well as clean up the spider web of vaccum lines. I have deleted both smog and EGR. I can get pics up tommorow..... any whlp would be appreciated!
-Matt-
Old Aug 8, 2005 | 10:15 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Do you mean, "Any welp would be appreciated?" If so, here I am!
You can eliminate some vacuum lines with the removal of EGR and (I assume you mean) A.I.R., obviously. That canister control valve in front of the carb could be moved closer to the canister by running longer lines over there, getting it out of the way.
Wiring would be a matter of unbundling the harnesses, running longer wires as required, and rebundling.
Old Aug 8, 2005 | 12:48 PM
Car: 87 camaro sc
between the carb and the charcol canister there is a mass of one way valves... what needs to stay/go in these vacuum lines. It is where most of the my uglyness comes from!
Old Aug 8, 2005 | 12:49 PM
Car: 87 camaro sc
yep I meant AIR sorry about the confusion
Old Aug 8, 2005 | 01:49 PM
five7kid's Avatar
How about EFE? With headers, mine is gone. Without A.I.R. or EFE, I was able to eliminate one TVS on the thermostat housing, as well as a vacuum tee shared with the PCV valve.
Does your car still have the vacuum diagram on it? By crossing out what isn't there anymore, you can see what isn't needed anymore.
I think I eliminated 2 check valves. I intended to reroute the canister control valve, but the swap project took so much longer than I had anticipated that I didn't bother. Yet.
Old Aug 8, 2005 | 03:57 PM
Car: 87 camaro sc
EFE? I am unfamiliar with what you are talking about. I am running hedman elite headers so I doubt I have it
Old Aug 8, 2005 | 05:15 PM
five7kid's Avatar
"Early Fuel Evaporation". AKA "heat riser valve". Between the passenger side exhaust manifold and y-pipe.
Old Aug 8, 2005 | 11:58 PM
Car: 87 camaro sc
AHA... I definatley wont have one after headers. thanks man
Old Aug 11, 2005 | 01:22 PM
Dirty Dave's Avatar
Car: 85 Berlinetta
Engine: sort of working
Transmission: B&M 700R4
I got rid of the EFE, plus just recently removed the Cruise control. That took care of some more vacuum lines and wires. I also zip-tied the massive, ugly canister control valve to the radiator hose to keep it from just hanging in mid-air. I'd think twice about moving it toward the charcoal canister simply because you're adding more (longer) vacuum lines. Just more spots for problems IMO.
Old Aug 11, 2005 | 01:26 PM
Car: 87 camaro sc
thanks man... looking at the diagrams why do I need more than one valve after I've removed egr, efe, and Air?
Old Aug 11, 2005 | 07:04 PM
Car: 87 camaro sc
between the carb and the canister** thought I'd clear up the last post
Old Aug 12, 2005 | 08:53 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
How are you guys getting rid of the EFE valve? - I tried, but my Y-pope didn't fit back up right to the header as I recall.....
I still have mine, just using it as a spacer. I bashed the butterfly valve out of it! hehe.
Old Aug 12, 2005 | 09:08 PM
Vader's Avatar
Hard nylon tubing with bonded rubber hose adapters at the ends would help clean it up. You can custom bend the nylon tubing by heating it slightly - Just like the factory did.
Old Aug 15, 2005 | 01:27 PM
five7kid's Avatar
Sounds like you have carb-type TES. The TPI and non-emissions type headers don't use the EFE valve.
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Uglybronco
South Central
Oct 25, 2015 09:22 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
