Fuel well plugs?
Old Aug 8, 2005 | 10:18 PM
Frank_Blotto's Avatar
Car: 87 Camaro Z28
Engine: LG4, CCC
Fuel well plugs?
Does anyone have a picture of the underside of CC Q-Jet? I think my fuel well plugs are leaky, because it's still rich after I did a partial rebuild (stuff directly under the airhorn). They can be accessed just my taking the carb off the manifold, and flipping it over, correct? Thanks in advance.
Old Aug 8, 2005 | 10:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I don't have one handy, but it has been posted before.
Old Aug 8, 2005 | 10:29 PM
Car: 87 Camaro Z28
Engine: LG4, CCC
Figured it had been, but didn't get much searching for fuel well plugs. I guess I'll try some more combos.
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
This is the best I could find quickly. You don't just turn the carb over, you have to disassemble it.
<img src="https://www.thirdgen.org/techbb2/attachment.php?s=&postid=2460000">
Old Aug 8, 2005 | 10:33 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Here's a better one, thanks to CarCraft
<img src="http://carcraft.com/howto/p123761_image_large.jpg">
Old Aug 8, 2005 | 10:57 PM
Car: 87 Camaro Z28
Engine: LG4, CCC
aaah, damn. I just had it apart. What a pain. Are these plugs on the bottom of the float bowl assembly? If so, that means I have to tear it down from the top, further than I did before, and redo everything I already did?
EDIT: bleh, I just answered my own question. Is it possible to remove the carb, then just remove the thorttle body assembly, or do I need to go through the top, removing the airhorn, then the float bowl assembly, and all the sensors and whatnot?
Old Aug 8, 2005 | 11:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Well, the bolts holding the throttle body onto the float bole go in from the top, so you're probably taking most of it apart anyway.
Old Aug 8, 2005 | 11:06 PM
Car: 87 Camaro Z28
Engine: LG4, CCC
Ugh. Sounds like a pretty big job. No shortcuts to it, just gotta start from the top and work my way down? If the plugs are on the bottom, that means I'll need to remove the carb from the manifold as well.... sounds like my day off is all booked up. Thanks for the resposne Aperion, it's nice to have someone reaffirm the things I think I know, seeing as this is my first time doing all this.
Old Aug 8, 2005 | 11:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You might not have to take everything off at least. Take the top cover screws out, and see what's keeping the throttle body from falling off, if anything.
Old Aug 8, 2005 | 11:12 PM
Car: 87 Camaro Z28
Engine: LG4, CCC
Ok. Doesn't sound that bad I guess, as long as I don't have to go from the top and remove the airhorn and do the lean mixture screw and all that stuff again. Thanks again.
Old Aug 9, 2005 | 11:24 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You can take the throttle body off without taking the air horn off. Only remove the screws that go all the way through to the TB - the two under the choke butterfly can stay in, for instance. Then the screws that are underneath the TB.
You can get to the primary wells without removing the TB, but it's better to have it open.
Old Aug 9, 2005 | 11:25 AM
five7kid's Avatar
Looks like Car Craft used RTV rather than epoxy.
Old Aug 9, 2005 | 11:26 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Whatever they used, it's not JB Weld so it has to be wrong.
Actually, it was Sean Murphy that did the work in the article.
Old Aug 9, 2005 | 01:26 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
any idea how that was painted?
I think I have that article at home (maybe..), if it was done by Jet...?
I'm planning on making my q-jet really pretty for the next motor, I was thinking either paint like that, or nickel plated...
Old Aug 9, 2005 | 01:34 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
How what was painted?
Old Aug 9, 2005 | 01:45 PM
five7kid's Avatar
The Car Craft fuel bowl.
Looks like a grey-tone photo to me. Or whatever they call that tech photo stuff.
Old Aug 9, 2005 | 01:54 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yeah, just looks clean to me.
If you wanted to paint it, you could remove absolutely everything from it (including the tubes in the vacuum ports), mask the top and bottom mating surfaces (including covering the bores), spray it and reassemble it.
Old Aug 9, 2005 | 03:22 PM
five7kid's Avatar
Eastwood carries the paint. I thought that had been discussed in a different thread.
Old Aug 9, 2005 | 04:53 PM
Car: 87 Camaro Z28
Engine: LG4, CCC
Ok, so I've gotten everything off, and it really wasn't too bad. Under the airhorn servicing is way more of a pain in my opinion, and having done it once. I keep reading that I'm supposed to punch in and/or file the fuel well plugs? Is this nessecary? Which part would I be punching in, the flat spot on the secondary plugs? What part am I filing?
Old Aug 9, 2005 | 06:35 PM
five7kid's Avatar
Just put the sealant, whatever you're using, over the plugs after thorough cleaning (brake parts cleaner is a good choice, doesn't leave residue).
Old Aug 9, 2005 | 06:42 PM
Car: 87 Camaro Z28
Engine: LG4, CCC
Ok, done and done. I used carb cleaner and JB weld. The area around the primary plugs was super dirty and there was lots of gasket material stuck to the fuel bowl surface. The area around the secondaries was quite clean. It actually looked a lot like that first picture, sans the epoxy. Thanks for the help.
Old Aug 10, 2005 | 02:47 PM
asellesa's Avatar
Car: 1986 z28 or a 1979 Firebird
Engine: 305 in both
Fuel well plugs
Why do you plug up the fuel well plugs?
Old Aug 10, 2005 | 03:32 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The well plugs fill holes needed temporarily during the manufacturing process. Over time they can start to leak fuel into the manifold and cause an over rich condition. Plugging them with epoxy prevents this.
Glowsock
Jul 24, 2025 03:15 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
Brcharrelson
Aug 26, 2015 07:47 PM
