Jet sizing and idle mixture.
Old Aug 11, 2005 | 07:11 PM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
If I set the idle mixture using a vacuum guage, (talking about a Holley 650DP), then change the jet sizes up a bit, do I have to set the idle mixture again?
I have one side of the motor running hottwer than the other, so i'll adjust the idle mixture, but then if it is still too lean, I'll have to change the jets. Just wondering if i have to do the idle mixture again.
My passenger side CAT was glowing red under the shield, the driver's side wasn't.
Old Aug 11, 2005 | 10:17 PM
BT283's Avatar
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
seems like you need a new Cat on the pass side
Old Aug 12, 2005 | 06:58 AM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
The CAT is brand new.
Old Aug 12, 2005 | 08:10 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Look for a bad spark plug wire on that side of the motor.
Old Aug 12, 2005 | 09:20 PM
RMAXZ28's Avatar
Car: 86 Z28
Engine: 383 stroker
Transmission: th350
Axle/Gears: 4.10
The jets in a holley dp carb have nothing to do with the idle mixture. When the throttle plates are closed you draw fuel from the idle system. When the throttle plates are opened you draw fuel from the jets. You should not have to play with your mixture after changing jets.
Old Aug 12, 2005 | 10:22 PM
BT283's Avatar
The CAT maybe brand new but somewhere you have a rich condition that is what causes a CAT to glow red and it will also cause it to go bad.
Old Aug 13, 2005 | 05:03 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Lean condition will make it run richer. I jetted up the carbs and richened the idle mixture, and the glowing Cat went away.
Old Aug 13, 2005 | 05:09 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
If it's lean, then how can it be rich??
Old Aug 13, 2005 | 07:00 PM
BT283's Avatar
HUH?
Old Aug 13, 2005 | 07:02 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Heheh, you'd think I was drinking. I meant that the lean condition would make it run "hotter."
Sorry for the confusion. Thanks for all the help guys.
BTW, it's running full with dual 3" and UltraFlows, and they blow the Flowmasters out of the water. They sound awesome.
toronto formula
Nov 10, 2015 06:17 AM
bamaboy0323
Sep 3, 2015 06:07 AM
fasteddi
Sep 2, 2015 10:29 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
knight72
Aug 10, 2015 09:32 PM
