installed new carb and intake
Car: 1984 Camaro Z28
Engine: LG4
Transmission: th-700
replaced my stock quad jet and manifold with holly 600 manual choke and a street dominator. having trouble with the transition. anyone out there done a similar change? how did you do? throttle linkage and manual choke giving me trouble, cant get it started as of now.
Transmission: 4L80E/4L80E
Many people have done it, at least something similar.
Holley makes some studs to mount the throttle cable. You can search for them on www.summitracing.com , for instance.
What did you do about the distributor? Unless this is a Canadian car, it will have to change (unless you want to do some creative PROM tuning).
Engine: LG4
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
it is part number HLY-20-95 on summitracing.com
it is what i used to hook up my throttle cable and TV cable on my holley
the throttle goes in the top one and the TV goes in the bottom....and it bolts right up to the base plate on your holley carb..... hopefully this helps....
Car: 1984 Trans Am
Engine: Vortec 355
your car will run on the CC distributor...but not well....i had my stock carb and distributor on my vortec motor for a couple months before i had all of the parts to do the swap....
Engine: LG4
the vacuum that come out of the rear right side of the carb, where the EGR is mounted on the manifold. is that where the power brake vacuum hose goes?
sorry if this sounds stupid, first time to do any big changes on my own.
Originally posted by 84camaroZ
any tips on a decent priced carb? i had no idea i would need to change it right away.
Summit has a new HEI for something like $140-150. You can get used for less. I'd recommend new, since it will have a good coil & module.
Engine: LG4
Did you mean distributor?
That's not a typo, that's a brain fart.
http://store.summitracing.com/defaul...6&autoview=sku The black cap versions have aluminum terminals, red & blue have brass.
Engine: LG4
thanks for the link, whats the difference in using aluminum or brass???
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
Originally posted by Stekman
Brake booster TYPICALLY goes here:
Engine: LG4
this is the problem that i am having. where ive been shown to put my booster vacuum is the same spot i put this other vacuum. Does anybody know what this vacuum is?
86IROC112
Aug 17, 2015 02:00 PM
