high idol most of the time
Old Nov 6, 2005 | 10:39 AM
killer_pigs's Avatar
ok i have a 1984 t/a recently got rid of the q-jet, and put on a edelbrock 600 cfm electric choke carb. when i start it up it will start fine and go its normal idol. (600 rpms). after i start to drive it and just sit at a light or whatever then the idol will go upto 2100-2200 rpms unless i gas it a littlebit then it will return back down to idol. it always does it and will always return back to 2100-2200 rpms after start to drive again till i gas it a little at the light or just parked getting ready to turn it off. can anybody help im sure this isnt helping my gas mileage any.
Old Nov 6, 2005 | 03:04 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
It sounds like a problem with the choke. Make sure you are getting proper voltage to the choke. Also, you replaced the distributor when you swapped carbs, right?
Old Nov 6, 2005 | 06:11 PM
yeah im getting enough to the choke 12v and no i didnt replace the distributor dont see why that would be the problem though its newish.
Old Nov 6, 2005 | 11:12 PM
85cmroz28's Avatar
Engine: L69
If you have a non-cc carb, you need a non-cc distributor. The cc distributor is made to work with the sensors that come with the q-jet carburetor system. I had the same problem and ended up having to replace the distributor.
Old Nov 8, 2005 | 08:53 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Either the throttle plates are sticking a bit of slop in the primary shaft. Clean up the bores & plates, then try tightening up on your return spring some. After using the carb cleaner, use some WD40 or a little motor oil to re-lube the bores.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Linson
Aug 21, 2015 02:12 PM
Fronzizzle
Aug 17, 2015 02:52 PM
