car hard to start when its cold
Old Nov 18, 2005 | 11:30 AM
kev2318's Avatar
Car: 85 firebird se
Transmission: auto.
before two pumps of the pedal mand the car starts now it wont start with out alot of pumps and i changed the fuel filter and now when i start it, it dont idle high to warm up its a real low idle but when its warmed up it will idle fine?
Old Nov 18, 2005 | 11:35 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Check that the connector for the electric choke is hooked up, and that it is closing when the engine is cold (top front flap on carb).
Old Nov 27, 2005 | 08:35 AM
kev2318's Avatar
Car: 85 firebird se
Transmission: auto.
the top front flap is not closing
Old Nov 27, 2005 | 09:00 AM
Lo-tec's Avatar
Alright, could be one of three things. Check for 12V to the choke coil connector with engine running. If OK, choke could be out of adjustment. With the engine off, rotate it clockwise a little looking from the pass side fender. Move the throttle off idle and it should close the flap and go into the fast idle mode. If it does, try and start it. If it starts OK, verify the flap is firmly open once the engine is up to operating temp and it drops back to base idle. If it doesn't open up all the way, replace the choke.
Old Nov 28, 2005 | 05:50 PM
KissThis's Avatar
Car: 1984 Firebird V6
Could it also be that it is a lot colder now? Especially in Arlington.
Just my 2 cents.
Old Nov 29, 2005 | 07:10 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
it is true that it is a lot colder now, but that means that he needs a working choke in order for it to run properly during cold starts...
Old Nov 29, 2005 | 09:50 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
what carb is it?
if it's stock, see:
https://www.thirdgen.org/techbb2/sho...hreadid=332271
That should be a sticky this time of year, this gets asked so often.
Old Dec 1, 2005 | 11:32 AM
kev2318's Avatar
Car: 85 firebird se
Transmission: auto.
thanks for the info i'll check it out
midge54
Dec 27, 2019 04:14 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
86Base
Aug 8, 2015 01:34 PM
drathaar907
Aug 6, 2015 04:20 PM
