Engine running rich or lean or what?
Old Jan 11, 2006 | 10:35 PM
TVRPAUL's Avatar
Engine: 3.4lL 60* V6
Transmission: Tremic TKO 600 RR
I have the 3.4L Crate Egnine with the 390 Holley on it Edelbrock Preforma intake, cams are what came with the engine, Mallory distrubotor, improved exhaust not true header. My question what the care was on the dyno it was found that the
The car is running rich (11.4:1 and it's got white plugs!). I thought white looking plugs was a lean sign yet the ratio is 11.4:1 What does every think about this??
Paul
Old Jan 12, 2006 | 04:41 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Did you shut down and pull the plugs immediatly after the dyno pull?
Old Jan 12, 2006 | 07:53 PM
TVRPAUL's Avatar
In responce
I was not there when it was dynoed. Please explain why you ask.
If I remember well before I had the car dynoed I had checked at least one plug #1 at one time and was suprised to see the plug on the white side.
I would imagine the plug(s) were pulled at some point after the pull but don't know if right after the pull I will find out.
Paul
Old Jan 12, 2006 | 09:40 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
white plugs don't always mean rich. It sounds like you're only looking at the insulator.
BTW, many stock systems run at 11.5:1 at WOT, so it's not a disaster or anything.
pull a plug and rub your finger across the outer ring. You should get some black soot indicating a slight rich condition. A ton of soot is very rich, and so on.
Old Jan 12, 2006 | 09:58 PM
TVRPAUL's Avatar
A responce
The 11.4:1 the way I was told was rich and the plugs being white was a sign that it is lean?????? ratio rich but white showes lean?? a bit of a contradiction, like jumbo shrimp LOL
Paul
Old Jan 12, 2006 | 10:07 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: A responce
Paul
Yeah you've already said that once, and I answered. The person telling you didn't explain it well enough to you for whatever reason and is the one who confused you.
Old Jan 12, 2006 | 10:10 PM
TVRPAUL's Avatar
They sure did. It is a new engine and I don't want to wreck it
Old Jan 13, 2006 | 12:04 AM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
I dont think that ratio is rich.
Are the plugs clean and white are burned and white?
Are the plugs the right heat range?
Can you smell gas in the tail pipe?
I dont think you have a problem.
Old Jan 13, 2006 | 12:11 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i would imagine the plugs are white from day to day driving which is typically normal. under WOT in a dyno session perhaps the engine is running on the rich side, but not to terribly so. Under part throttle day to day driving sounds like it is close to being right on. try upping the main jets 2 sizes and check the plugs again if you're worried about it.
Old Jan 13, 2006 | 04:51 AM
TVRPAUL's Avatar
responce to 305sbc
305sbc when I said they sure did, I ment the the people as you said did not explain themselvs clearly.. Rereading my post I felt I was not clear.
Old Jan 15, 2006 | 02:01 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
the only way to really tell how the car is running from the plugs is shut the car off right after doing a run.
so lets say your doing day to day driving. the carb is prolly tuned to be a tad lean. helps on gas. when you pull the plugs you are only going to see what has happend the last little bit of driving that is all.
to see how the plugs read during the dyno run you would make the pull and then right at the end of the pull at the end of your rpm range shut the car off. (this isn't let the car coast back down then shut it off it's at your highest rpm reading you are going to pull to shut the car off at that point.
then you should see your plugs, doubt they should be white at that point
Old Jan 15, 2006 | 02:13 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I have a quick ? I pulled my plugs the other day because the car was sluggish and backfiring. The motor has 2800 miles on the rebuild and I am running a holley DP. The plugs on the drivers side had ALOT of carbon build up but the plugs on the passenger looked fine, maybe a little white but nothing to make me worry. I have been doing alot of reading and I have come to the conclusion I need to rejet it because I am at 7000 miles above sea level. Does this plug problem sound right to anyone and is there anything I can do to adjust the carb manually to fix the problem or do I have to re-jet it. I can smell alot of gas in the exhaust and it is sucking gas like mad.
Old Jan 15, 2006 | 09:54 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I would try to determine the problem for sure first before rejetting.
What type of intake manifold are you running?
Old Jan 15, 2006 | 10:08 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I have an edelbrock manifold. This engine is new to me and I am used to the Iron Duke so I am just learning about 350? The person I bought the car from didn't tell me anything I needed to know about the rebuild and I think he is a dumb *** It also has an accel dizzy, a mild cam, and I wish I knew more about the motor than I do. Is there any way for a lay person to look at what he has and make a determination on what he is running? The car runs great and all but runs very rich, the person I bought it from was able to tell me that the motor was built to run low 12's, and I guess I believe him because it burns tires even if I don't mean it to
Old Jan 15, 2006 | 10:19 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
That's a brand name. What type? single plane? dual plane? tunnel ram?
Old Jan 15, 2006 | 10:22 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
There you go again? It has a holley double pumper on it so I assume a dual plane? I am trying to learn so I can work on it. Thank you for helping me
Old Jan 15, 2006 | 10:45 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
What type the intake is has nothing to do with the type of carburetor.
Here's a dual plane intake manifold.
http://static.summitracing.com/globa...e/edl-2101.jpg
and here's a single plane manifold.
http://static.summitracing.com/globa...e/edl-5001.jpg
Old Jan 16, 2006 | 10:37 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Is there any way to tell the difference without pulling the carb?
Old Jan 17, 2006 | 06:43 AM
TVRPAUL's Avatar
Single, double plain
Which is better the single or double, if that is the correct way to ask, and in what way and why? and if you were to pick between the two which would be the better pick, or are each one for a specific puropose??
Old Jan 17, 2006 | 07:47 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
each one is more or less for a specific reason.
the single plane manifolds with the large plenum generally have a weak signal to the carb and low intake velocity so the lower end power isn't quite so great. the dual planes help eliminate that issue by using a divider down the middle that makes the plenum a little smaller and in turn helps with the lower end torque as well as mid range a little bit but then when the rpms start getting up it doesn'tquite have the oomph that a single plane would
Old Jan 17, 2006 | 11:32 AM
TVRPAUL's Avatar
Thanks for that lession. It seems Edelbrock uses the dual plane intake manifold for the 60* V6 for the 4 Brl.
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
squiggy2
Aug 9, 2015 09:30 PM
