What Manifold do you recomend
Old Jan 26, 2006 | 12:51 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
Axle/Gears: 3.42 Auburn
Originally i was going to use a Q-Jet but i recently traded for a Holley 4160. I was thinking of using eighter a Weiand Stealth, Weiand xcelerator, or a Edlebrock EPS. The car is goind to be a daily driver and im going to build a mild 350 and planning on running a little spray later on and im keeping the T5 Trans. Im not going to twist it that much probably 6500 at the most so whats the manifold you recomend
Old Jan 26, 2006 | 01:42 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
EPS is not bad for a basically stock engine that won't spin past 5000.
If you are going to spray it and spin it past 5500 or 6000, I'd strongly recomend a Edelbrock RPM - it will make plenty of power, and you won't lose any driveability. It should fit just fine under the stock hood with a drop base air cleaner too.
Old Jan 26, 2006 | 03:43 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
i'll put 2 cents in for the weiand stealth or rpm.
Old Jan 26, 2006 | 05:23 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
Yea i was thinking about the RPM but i was worried about hood clearance.
Old Jan 26, 2006 | 08:35 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
weiand strealth, edelbrock rpm, or holley street dominator intakes would be a good choice.ive used them all and liked them all.tho certain mods required me to upgrade to a bowtie victor jr intake muahahahahahahhahaa
Old Jan 26, 2006 | 11:09 PM
Air_Adam's Avatar
RPM will fit under the stock Camaro or Firebird hood. Just need to use a 14x3 drop base air cleaner. Mine will have an RPM Air Gap under the stock Z28 hood in the spring, and a friend of mine has an Air Gap under a stock Trans Am hood right now.
Old Jan 26, 2006 | 11:52 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
I already run a 14x3 drop base air cleaner on my tbi setup. But also when i put the juice to it i have to use a 1/2 sprayer plate.
Old Jan 27, 2006 | 08:12 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
RPM Air Gap. Best dp intake on the market hands down. Mine fits under stock TA hood with 1/2" spacer and 14x3" filter.
Old Jan 28, 2006 | 03:04 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
I vote for the RPM, but get the air gap.
I have a 350HO, RPM intake, 1405 carb, a 3x14 K&n, and it all fits under the hood.
about 1/4 inch to spare it seams...
Old Jan 28, 2006 | 10:46 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
holley street dominator all the way!
idle-7200rpm power band capabilities, can't go wrong with that!
Old Jan 29, 2006 | 06:31 AM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Are you talking about the old Street Dominarot or the new one. They dont produce the old one anymore and they are geting hard to find.
Old Jan 29, 2006 | 07:44 AM
you can get that intake from jegs.com or summitracing.com i ran one of those and i liked it as well
Old Jan 29, 2006 | 08:25 AM
mw66nova's Avatar
Engine: 7.0L
it's still available through jegs or summit. it's a high-rise dual plane intake.
Old Jan 29, 2006 | 10:58 AM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Ya you are talking about the new street dominaor. The old one was a high rise single plane intake.
Old Jan 29, 2006 | 12:11 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I recomend the Stealth over the standard RPM intake but either would work and should clear the factory hood. The stealth seems to have a bit more low end grunt. The new street dominator I havent tried yet but I did use the old SP one for a bit and it was fairly nice.
Old Jan 29, 2006 | 01:52 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
Vic jr with a 1/2" nitous plate and 3" drop base fits under my hood.
Old Jan 29, 2006 | 03:56 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
Now im thinking about eigther the Stealth or the new street dominator. I cant decide.
Old Jan 31, 2006 | 11:33 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
I decided, its going to be the street dominator. Now i just have to sell my current car to get some of my engine money.
Old Jan 31, 2006 | 11:59 PM
I think you will be satisfied with the street dominator intake. it offers a wide rpm range and also minimizes the risk of worrying bout your hood clearance.i ran one of these for 3 yrs till i decided to move onword and i liked how it performed
sailtexas186548
Feb 17, 2017 03:07 PM
Chas91Z28
Oct 22, 2015 10:12 AM
Zane Story
Oct 8, 2015 12:40 PM
86CamaroDan
Sep 29, 2015 10:08 PM
